| Home > Help Needed / General Tech Chat > Gearchange mounts | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
23rd Aug, 2010 at 07:23:31pm
My mounts are totally perished, is it possible to get uprated versions of these, polybush or even solid for example?
23rd Aug, 2010 at 08:32:56pm
bolt and spacer? if the engine is well mounted ( good steadys) the stick wont move much anyway
Yes i moved to the darkside |
23rd Aug, 2010 at 08:38:39pm
an internal gear change system will sort that On 26th Oct, 2004 TurboDave16v said:
23rd Aug, 2010 at 08:40:24pm
the issue other than the current mounts being knackered is that my KAD quick shift is really stiff and is a real pain to use as the whole mount moves.
23rd Aug, 2010 at 08:55:08pm
Does the KAD shifter not have a grease nipple on the collar? and does it not have a knurled collar that can be loosedned off a bit.
