Home > Help Needed / General Tech Chat > Turbo Manifold
yellowmini
Member #: 9040
Worcester
Does anyone have the dimensions? or a plan to build a manifold for A+ block that will clear the bulk head with turbo attached without the need for a bulkhead box.
Thanks
dan_up
Member #: 1835
Thame, oxfordshire
i think a few people have fabricated some up, have a quick search, failing that, you can order the mirage manifold from here.
http://www.miragemotorsport.com/
On 23rd Aug, 2010 Nic said:
Turbophil had a butt plug made that seemed to be suitable. He may have finished with it now and have it kicking around spare
Firstly, what turbo are you planning on using. It has been done with a T2, T25, RHF4, TD04 off the top of my head.
Otheres that will fit are GT15s, I think the GT17 is possible, but it's tight, not 100% if anyone have managed it.
Someone might let you have some measurements, but they will all be turbo specific.
Strech on here has a matty manifold with a GT17 on and no bulkhead box I do believe.
yes he does john, no bulk head box on his car
Another one to add to the list then.
If it can be done with a GT17 then I suspect that most suitable turbos can be made to fit as the 17 is pretty big.
yellowmini
Member #: 9040
Worcester
its a T2 im using, i just dont want to be cutting bodywork if i can avoid it and prefer to make my own rather than the £350 for mirage manifold as money is a bit tight for me :(
maccamcvey
Member #: 6673
Worral Sheffield
Matty has stopped doing his GT17 manifolds as mirrage have started doing one £30 cheeper (£220). Both do not need a bulk head box.
Advantage
Member #: 1450
Near Paris - France
either you already have a MIG or access to one but if you don't, the final tab is not gonna be far off a Mirage ...
Rusty by nature
