Home > For Sale > Mini City 1380
quinton
Member #: 1911
Engine Spec
Built by M.E.D
MED RS 1380 Engine
Single HIF 44 Carb with K&N Air Filter
MED L-D 1.5 ROCKERS
Fully ported/gas flowed 11 stud head with 36,31 valves with arp bolts
Compression Ratio 11:1
Forged Omega Lightweight pistons 73.5x7cc
Lightened/shot peened/polished/balanced cooper 'S' conrods with arp bolts
Reground/Ni-tempered/Cross Drilled/Wedge Bladed/Back Drilled/Balanced Crankshaft
Rebored/Refaced/new camshaft bearings/full steel caps with 4 bolt center cylinder block
Kent 286 camshaft
Lightweight vernier duplex timing chain
Steel backed competition oil pump set to 50 psi idle / 75 psi load
13 row oil cooler
KAD top & bottom engine steady's
Reprofiled Electronic Distributor for 286 Kent cam mapping
Standard Coil
Flywheel Spec
A.P bonded Clutch plate
Orange grade clutch cover
Ultra light steel billet backplate
Ultra light steel billet flywheel (All Balanced)
Gearbox Spec
Straight cut drop gears
Std gear set
New genuine baulk rings
Heavy duty double roller bearing
Heavy duty single roller bearing
All new needle roller bearings
Top quality central oil pick up pipe
MED X-pin differential
Standard Drive Shafts
New C.V joints
KAD quickshift
Cooling Spec
Uprated water pump
Minispares uprated 2 core radiator
Blue samco coolant hoses throughout
Standard thermostat
Multiblade Engine Fan
Exhaust Spec
Maniflow Stage 2 LCB
Maniflow stainless Steel Y-peice
Maniflow Stainless Steel centrepipe
Maniflow stainless Steel back box
Full system 2" O/D
Body Spec
Fully repainted Mini City shell (reshell registered with VOSA)
13x7 Superlight alloy wheels fitted with Dunlop SP9000 195/45 tyres which are virtually brand new
Brand new genuine front subframe
Brand new genuine rear subframe
Drilled/grooved front disc's with green stuff pads
Minisport finned alloy rear drums with Mintex 1134 shoes
Goodridge stainless steel braided brake hose's all round including from master cylinder to regulator
Goodridge stainless steel braided clutch hose from master cylinder to slave cylinder
Stainless Steel Bolts fitted throughout replacing every single steel bolt during rebuild
Genuine Sportspack arches
Brand new brake Lines
Brand new fuel line
Angel Eye head lights fitted
Black style metal number plates with chrome surrounds
Minisports stainless steel mirrors
MK1 grill and mustache
Internal bonnet release
Suspension Spec
Fully adjustable Hi-lo's
New knuckles
New dunlop donuts
Gaz 36 way adjustable dampers
All front and rear suspension arm's powdercoated/rebushed and rebuilt.
Interior Spec
Leather Top Dash
Leather Dash
Leather Bottom Dash
3x3 Clock system with Rev/Speedo/fuel&water gauge/oil pressure/vacuum/volt meter
Sparco Steering Wheel
Original Seats
New 10 piece carpet set
New Vinal door cards
Rear retractable seat belt's fitted
Rear companion boxes fitted
Rear & Side windows tinted
Heater Matrix still fitted
Center Console
I.C.E Spec
JVC KD-G721 Head unit
2 x 250 watts 3 way 6x9 front speakers
2 x 510 watts 5 way 6x9 rear speakers
1 x JBL 12" Sub
1 x 6 channel amplifier controlling all speakers
New cables run for it
Electrics
Completely rewired electrics with added additions:
Added electric fuel pump
Wiring added for additional electric coolant fan (not fitted)
New fuse box
Wiring added for spot lights (not fitted)
Added Alarm
Oil pressure switch controls fuel pump as a cut out system should oil pressure be lost
Added alarm has remote starting and central locking capability. (central locking not fitted)
I have owned this car for six and a half years and it is a well known throughout the local mini scene. History on the car is that it was rebuilt in 2006 after a really bad crash left her in cat C state. I took it upon myself to fully rebuild her from scratch and sourced another shell and commenced to build a real stunning show car and from the pictures you can see the results.
Having spent more than double the asking price, (receipts to prove) the labor (and lots of it) was only the free part. This is my most loved possession, however recent fatherhood has prevented me from enjoying her usage. I therefore feel that she deserves to go to a new home where it can get the love and affection it needs.
As I have said I've carried out all the work on the car myself to a professional standard with everything colour coded during the rebuild with the subframes and running gear all powdercoated either blue or silver. Whilst putting the car back together I also went out my way to replace every nut and bolt with stainless steel ones to prevent the problem I had of never being able to undo anything due to rust.
I have added an alarm which is also an immobiliser, but not thatcham approved as they wanted it installed via themselves so never got the certificate.
I built the car for track use as well as for show's but after building in 2006 I never really drove it very far as I didn't want to ruin the hard work put into it or be far from home should I get caught out in rain. The car has seldom seen a wet road and never been driven in the winter, just purely a summer car. Due to this the car has only done 2000 miles since the rebuild.
The engine has been run in and settled and when built it was expected to produce over 120 bhp but haven't had this proven.
The car was stripped again in 2008 where it underwent a full respray in BMW jet black and then put back together. (a few untidy places on it warranted the respray.)
When I insured this car it was only via HIC (herts) where I had an 'agreed' valuation of £10,000 due to the modifications and labor put into it. So when looking for insurance for it, it would be worth phoning them up as they know the car.
I was considering turbo-ing the car this year but after realising it still wont get me back to driving it, I have decided to find it a new home, however the few bits that I have collected up so far towards the project would be more than welcome to go with it. I had an electric fan fitted but since the car only ran at 1/4 in temperature I removed it but the wiring and relay are still fitted as everything is on proper connections.
Bad bits about it:
Speedo doesn't work, I have been battling with this since day one of owning the car. Needs a new set of clocks.
Rocker Cover need's replacing due to some unsightly rust.
Scratch on drivers side window ( Have two matching windows as replacements )
All these bad bits will be fixed prior to the car being handed over should it be sold.
Otherwise everything else on this car is perfect with the underside being clean as it has always been maintained.
When sold it will come with a fresh 12 months MOT and 6 months tax.
A custom made car cover is available for purchase should it be required.
This is not your average mini so unrealistic offers won't be replied to.
£8000 onco
Contact me on 07834987123 or my home phone 01793861341. Or pm me for any information.
Edited by quinton on 25th Aug, 2010.
quinton
Member #: 1911
Just to save everything the photo's of her can be viewed via my photo-bucket account.
this is a superb car to say the least, but because at the moment you havent had much intrest with the large figure!
i know theres no expence spared and its ............. well worth it *Yes*
but 8k is a whole chunk to find in these times un uncertanty .... maybe be auction it world wide and willing to ship at their expence ? just a thought
Edited by BENROSS on 26th Aug, 2010.
ministef1
Member #: 1791
Cranleigh, surrey
certainly worth sticking on ebay and putting a reserve down, mine was shipped to holland in the end. doubt your get that figure on here. good luck though
"Cars are a lifetime of pain"
quinton
Member #: 1911
Cheers for that guys. I'll prob do that this weekend.
this is a very quick mini indeed but quinton dont you have a itg air filter setup on this? you did when you took me out last time
