Home > Help Needed / General Tech Chat > rain is killing my car help
lanxter
Member #: 396
sheffield/rotherham
hi, well i have a problem, have a 998cc mini and have cosworth vents cut into my bonnet which i placed there mainly 4 when i put my turbo in for better air flow.
I was out the other night taking my gf for some food all was fine untill it started to rain, the car started to judder and even though i dropped it to second gear and put foot fully down it was still decreasing in speed till it cut out.
it started back up again straight awat but under reving made a funny kinda bubbling/poping sound coming from the exhaust area.
the car kept cutting out n stalling. managed to get home, the car does this however everytime it rains can any1 tell me what this is?
i know i sound block the vents up which is my plan 4 time being but there has got to be some other way around it?
thanx mark *happy*
speed is the best rush i have ever had!!!
add me lanxter@hotmail.com
Mike
Member #: 107
Sunny Sussex
water on the electrics? coil?
Nick
Member #: 154
Midlands
its more than likely the rain getting your dizzy area wet. try putting a bit of card or something between the dizzy and the grille. Mine does exactly the same ever since ive fitted a new dizzy cap, gonna dig out the 3 year old one had on before as that never got affected by the rain!
adam1330
Member #: 238
essex
yep, sounds like the dizzy is getting wet to me aswell.
put a cover on to shield it and then go for a drive in the rain! should have no problems..
or something to divert the water from your vents away from the lectrics a la std metty turbo style.
sort it at the root cause like the members says.
vents! and sort a sheild for the dizzy its a must
but get some silicon spray for the leads and the cap and coil and apply this, it gives you some more insurance against the rain
this will help to repel any moisture on these items and insure you GF gets her food
pot_dan
Member #: 326
bradford, west yorks
yup mine does this when its wet too, dried and cleaned the cap and leads etc and it was ok, tho struggles a little i found it only relaly does it under load toh, so just tickle the throttle and take it relly steady, least you will get home, i had to dothis for 12 miles *surprised*
Dan
jamesfawcett
Member #: 218
Bingley, West Yorkshire
...and it makes dans sound like a subaru!
Use the standard type dizzy splash shield and you should find it will be a lot better. For a std front it is a plastic thing approximately square in shape that sits in front of the dizzy on the front panel.
lanxter
Member #: 396
sheffield/rotherham
cheers, got sum persecs (think thats how ya spell it) so gunna cover the vents for the time being and ill get straight on with the other things you lot have suggested.
thanx again
mark :)
perspex.....
lanxter
Member #: 396
sheffield/rotherham
lol ta mate, sorted problem today found heavy ammounts of duckt tape seemed to sort the problem of leaking water into the car, fan belt was a bit of a pain in the back side to swap over but all seems fine, just got to sort them electrics now
thanx 4 ya help
mark :)
