Home > Help Needed / General Tech Chat > alloy tanks, fuel pump, fuel gauge amd other questions
jamz
Member #: 2292
Tool
Herne Bay, kent
right now i have got myself a carbon bootfloor i need to invest in alloy tank and fuel pump. my questions are...
what do i need on the tank? outlet, return, breather, filler neck and sender hole? thats it right?
should i get baffled or foam filled?
what type of fuel pump do i need to get?
never even thought about after market fuel guages but what send do i get for alloy tank?
ad any other infomation you have would be appriciated
sorry for all the newb questions, but im on my phone and i cant use the searcha swell as id like to.
cant beat a good blowout.
They sound about the correct bits you need.
You can get vdo senders for various depth tanks, they need a ring with m5 threads welding on the tank.
These work with a lot of gauges (vdo obviously and some digital ones allow you to calibrate them), but on the std one they seem to work on a half scale. I did figure out the resistance and try to improve mine but now it doesn't work at all.....
Pump wise I'd go for an external injection one, unless you get the bits for an internal one built into it.
Baffled or foam its up to you. Foam tanks take a bit of waiting around at petrol stations whilst the level drops and make sure there's a cut out in the foam so you can get the nozzle in.
And dontt forget to think of some method of holding it down
sturgeo
Member #: 1778
Northants
I've been looking at all this lately, decided on this tank: http://cgi.ebay.co.uk/ALLOY-FUEL-TANK-5-GA...les_CarParts_SM
something like this for the pump: http://cgi.ebay.co.uk/NEW-Petrol-electric-...les_CarParts_SM
and something like this for the reg: http://cgi.ebay.co.uk/MG-Metro-Mini-Turbo-...les_CarParts_SM
sturgeo
Member #: 1778
Northants
How to the fuel level senders work if you fill the tank with foam? surely the foam will get in the way of the float :/
They are in a tube and you cut away the foam.
Look on the merlin website at the vdo sender
jamz
Member #: 2292
Tool
Herne Bay, kent
what about like a facet fuel pump?
i dont understand all this sender shit> haha is it hard to set up? what do people do if they dont have a fuel guage?
maccamcvey
Member #: 6673
Worral Sheffield
maybe work out a rough mpg and reset a trip comp every time you fill up, work out how far you will get on a tank and fannies your ant!
Tbh my gauge isnt working at the moment, but i have had a couple of close calls...
No you need an injection pump
AWDmoke
Member #: 713
Western Australia
A piece of wooden dowel is the favourite at the race track.
Then you can accurately have the minimum required for one event.
On 24th Dec, 2008 Nic said:
jamz
Member #: 2292
Tool
Herne Bay, kent
so when it comes to mot time. jsut have a guage in there but it dont work lol. ideally if im not going to get one to work then i dont wont one. i dont mind using the wood trick tbh. ill prbs get a fairly big tank for a mini loike 6.5 gallon. then ill just work out rough mpg and check the tank when im close. i wont be driving the car much on long journeys anyone so at track days i can just check before next outing and the drag stipp same thing. and to tget to the places ill probs trailer it anyway unless its brands or lydden cos there local.
so that one in the link is the one to get? is it litrally tank outlet fuel line to the lump then fuel filter then straight to the reg? thats it? so the pump pulls out the tank then pushes up the line
jamz
Member #: 2292
Tool
Herne Bay, kent
