| Home > Help Needed / General Tech Chat > Door shut | |||||||
67 Posts Member #: 8744 Advanced Member |
26th Aug, 2010 at 10:23:29am
My mini door dosent seem to line up right the door it's self needs to move towards the front a panel! I am wondering how this is done! Thanks mike |
26th Aug, 2010 at 10:33:56am
There are some shims in between the hinge and the hinge panel On 11th Feb, 2015 robert said:
26th Aug, 2010 at 10:34:49am
On 26th Aug, 2010 apbellamy said:
There are some shims in between the hinge and the hinge panel Hopefully I seriously doubt it! |
26th Aug, 2010 at 10:38:06am
I will have to take a look on a dryer day, hopeduly there is or else what could I do? As want to sort it while the doors off! Mike |
26th Aug, 2010 at 10:43:33am
I've seen cars where they have had a hinge panel repair section put in, but fitted inside the door shut. This effectively closes the gap up for the door by a couple of mm. On 11th Feb, 2015 robert said:
26th Aug, 2010 at 10:57:02am
Or the hinge pins are badly worn - before altering shims (if there are any), can you lift the door up and down with it nearly closed ???
26th Aug, 2010 at 11:03:05am
Also, there should be oval (removable) plates the other side of the A pillar where the nuts tighten down - if these have been ommited in the past and just nuts/washers used (or worse still just nuts) the weight of the door tends to distort the hole that the stud goes through allowing the door to drop or move backwards. Schrödinger's cat - so which one am I ??? |
26th Aug, 2010 at 01:32:07pm
I remember the door seemed solid that's what confuzed me! Mike |
