| Home > Help Needed / General Tech Chat > suspension geometry set up in yorkshire | |||||||
![]() 539 Posts Member #: 6807 Post Whore York |
27th Aug, 2010 at 11:24:29am
After fitting adjustbale bottom arms, tie bars, rear tracking brackets etc i need it all aligning. With no flat space to sit the car on and do it myself where would people recommend to go in yorkshire?
27th Aug, 2010 at 12:22:29pm
Where in Yorkshire are you? It's a reet big place Fastest 998 mini in the world? 13.05 1/4 mile 106mph
27th Aug, 2010 at 12:31:57pm
As regards to set up, its a very personal thing, am sure there was a thread on this. Do a search.
27th Aug, 2010 at 12:35:26pm
In order to do mine I took measurements from the outer end of the lower arm to the subframe and from the lower ball joint to the front of the tie bar then reproduced these meaurements when I fitted my adjustable arms and tie bars. Got it spot on Own the day
27th Aug, 2010 at 04:38:22pm
On 27th Aug, 2010 adcyork said: you don't need a flat space, just create four level platforms using whatever you can,
After fitting adjustbale bottom arms, tie bars, rear tracking brackets etc i need it all aligning. With no flat space to sit the car on and do it myself where would people recommend to go in yorkshire? Also could someone recommend me some settings? The car is used for typical "fast road" uses, but also covers long distance so tyre wear is an issue but certainly not a priority. whatever settings you put in ,castor ,camber ,make sure they are even at the very least, 1/2 to 1 deg camber, 3-5 degs caster, set toe straight ahead to start with , the turn one side in 1/2 a turn, see how it feels, carl |
![]() 159 Posts Member #: 1997 Advanced Member Lichfield |
27th Aug, 2010 at 05:14:48pm
On 27th Aug, 2010 Mr Joshua said:
In order to do mine I took measurements from the outer end of the lower arm to the subframe and from the lower ball joint to the front of the tie bar then reproduced these meaurements when I fitted my adjustable arms and tie bars. Got it spot on so you adjusted your adjustable arms and rods to be the same as standard ones? why change them for adjustable ones at all? |
28th Aug, 2010 at 12:28:44am
On 27th Aug, 2010 wil_h said:
Where in Yorkshire are you? It's a reet big place I'm in york, as i see you are. Do you have a place that you go with the race car wil? |
29th Aug, 2010 at 09:18:50am
Is Huby garage still trading, years ago it was run by a chap called Denns Cope, he used to compete in minis and will be able to do it , if he's still around
29th Aug, 2010 at 07:12:19pm
Where in Yorkshire are you? It's a reet big place I'm in york, as i see you are. Do you have a place that you go with the race car wil? I go in my garage and twiddle about. I'm happy for you to pop round and I'll have a twiddle with your motor. If it's not right you can always come back, I don't charge. The only gauge I don't have is a toe gauge. My toe gauges are home made (some wood and string),repeatability is ok so it's not a problem. I might be able to borrow a single axel one, which would be ok as long as you think about other measurements at the rear to keep side to side even. If you fancy a pro having a go then Tockwith mororsport come recommended http://www.tockwithmotorsports.net/index.html Fastest 998 mini in the world? 13.05 1/4 mile 106mph
29th Aug, 2010 at 08:28:06pm
thanks alot will, pm sent |
29th Aug, 2010 at 08:59:26pm
adcyork, if you get wil to do your camber etc, I can set your tracking if you want to travel down here, I have a set of proper Dunlop optical gauges.
29th Aug, 2010 at 10:15:10pm
That what tm spirit is about, i think thats a brilliant offer from two respected members
30th Aug, 2010 at 01:09:13am
On 29th Aug, 2010 Tom Fenton said:
adcyork, if you get wil to do your camber etc, I can set your tracking if you want to travel down here, I have a set of proper Dunlop optical gauges. Thats very kind tom, thanks alot. I'll see how we get on at wills and i may give you a shout depending on how we get on, thanks again. |
