Home > Help Needed / General Tech Chat > Mpi/A/A+ Heads
Tweaked
Member #: 2873
Hi all, had a search but i couldn't find any definite answers to my questions so here they are:
1) Are MPI heads the same as A and A+ heads??
2) Can I run an MPI Inlet mani on a A or A+ head??
Thanks in advance
Cheyne
The MPI castings differ in that they have mounting holes for the alternator bracket & no temp take off hole.
Amp
Member #: 7856
I believe the MPI head has no water temperature sender, although this is rectifiable, also there is the alternator mounts on the head but that isn't really relevant!
*yeah, what Phil said*
Edited by Amp on 27th Aug, 2010.
Tweaked
Member #: 2873
Ok thanks for the replies. Other than what has been stated above are they all the same internally then??
So would i be able to use an MPI inlet mani on an A/A+ casting then??
Obviously I would need to be able to control the Injection but that isn't a problem.
Thanks
Cheyne
Edited by Tweaked on 27th Aug, 2010.
Yes you can use the MPI manifold on another head.
Tweaked
Member #: 2873
Ok cheers mate
Carl S
Member #: 1761
Stalker
I am currently fitting an MPi manifold to a pre injection head, and yes, it fits fine.
The ports differ in size slightly but it shouldnt make any odds, but thats because im using a 998 engine.
Edited by Carl S on 27th Aug, 2010.
If you use a head that cannot accept the manifold locating rings of the MPi inlet, you need to carefully position the manifold when bolting it up, or, mark everything up in relacion to a manifold gasket then drill and fit dowels.
Tweaked
Member #: 2873
Ok thanks Carl S and Sprocket, seems thats the road i'm going to travell down.
