| Home > Help Needed / General Tech Chat > kenlowe fan fitting | |||||||
![]() 78 Posts Member #: 8913 Advanced Member seaford, east sussex |
30th Aug, 2010 at 05:45:55pm
got abit of a nightmare situation, i recently bought a kenlowe fan from mini spares. i wired up the control unit and fitted the fan to my radiator. went to mount the radiator in the car and found it wouldn't fit. problem is i have a flip front and the brace bar is only giving 30mm clearance at its lowest point. so i have taken the fan off and found that if mount it the over way round so its back is against the radiator and the fan facing out towards the wheel it will fit, however the fan will then push heat from the rad into the engine bay not away from. unless........ if i wire it up the oppersite way will it rotate the oppersite way thus sucking from the rad and not blowing into the engine bay? does this sound ok or will it melt the motor in the fan? lol anyone any suggestion. dont think mini spares will let me send it back.
30th Aug, 2010 at 07:44:40pm
it depends on the model some can run both ways, however I have mine fitted to the inner wing and I just turned the fan around, as it cant be reversed electronically, my car does have a rad shroud so the rad is "sealed" to the inner wing, which I think helps air flow.
30th Aug, 2010 at 08:05:25pm
not sure about mine as it has a sticker on top of the fan which states direction and air flow. might phone kenlowe tomorrow see if it can run both ways if it does it would be most helpful.
30th Aug, 2010 at 09:01:28pm
Depends on the motor they have used,
2nd Sep, 2010 at 11:19:42am
dont suppose anyone knows if the pacet fans fit between the radiator and the brace bar on a flip fronted mini?
3rd Sep, 2010 at 08:26:58pm
does anyone know which way the mini fan cools does it blow or suck air? because if it sucks air from the wing through the rad i'll still be able to use my kenlowe
3rd Sep, 2010 at 08:39:51pm
Mechanical (on the end of the water pump) pushes air from the engine out into the wheel arch. It does this whichever way round you fit it, it just does it better if it's on the right way around.
