| Home > Help Needed / General Tech Chat > Quick :D are brake caliper bolts 3/8ths? | |||||||
15th Feb, 2005 at 08:54:22pm
Just a quick question, went to a nut and bolt supplier today to get new caliper bolts as the ones im using with my 4pots & vented disks were not long enough. He matched them as 3/8" UNF i think thats how you type it. I gave him the original bolt which only screwed in a few threads on the test 3/8"unf nut. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
15th Feb, 2005 at 08:55:15pm
by the way just asking because im stuck at my mums house iwth the calipers off waiting to bolt htem back on, and didnt want to damage my hubs :) Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
15th Feb, 2005 at 08:58:14pm
Which hubs are you using? Mini hubs are 3/8 UNF, but Metro hubs are M10.
Edited by Tom Fenton on 15th Feb, 2005.
15th Feb, 2005 at 09:11:20pm
I have some here some era turbo caliper bolts, BUT to get the 4pots centralised over the disks i have to spacer them with washers, its been like this since i bought the car but with just 3/8bolts then. I will use the era bolts, but thats the problem im having that the bolt doesnt go far enough into the hub to keep me happy with piece of mind :) Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
15th Feb, 2005 at 09:12:10pm
so it is not possible to get some era bolts made up or do we need to order them from mini spares? i did buy a 4 pot kit and was told i had ERA bolts with them but they turned out to be normal 2 pot ones as i dint know what i was looking for. i guess a nut and bolt place would do them cheeper for a few sets than mini spares will do?
15th Feb, 2005 at 09:22:21pm
Why are you having to use washers to centralise the calipers on the discs? I have Metro 4 pots and Metro vented discs mounted on Mini hubs with no problems at all?
15th Feb, 2005 at 09:29:40pm
mine are definately mini hubs, its just where the caliper sits, the hole that you look odwn to see pad wear isnt in the middle without the washers :/ i will be able to get a pic when i get home, do both pads have the same clearence on each side of the caliper on yours arround the disk? I use about 6-8 thin washers Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
15th Feb, 2005 at 09:33:44pm
What discs are you using? Are you using Metro or Mini drive flanges? Mine fit central to the disc e.g. equal space either side. To be honest they look like they could have been std equipment, e.g. fit properly with no bodgery needed.
15th Feb, 2005 at 09:37:09pm
ooh im confused now. I willbolts them together to get home to get camera and take a good photo tomorow. If it helps though i used a standard mini driveshaft & cv joint on one of them as a replacement last time. my wheels are an extra bit wider than using standard brakes though and my 13x7s are still wider than group5 euro arches. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
15th Feb, 2005 at 09:39:52pm
As tom says, sounds like the drive flanges are the wrong type!
15th Feb, 2005 at 10:07:30pm
Oh ok! pot dan just mentioned that metro ones have a lip on them. Ill get a pic tomorow.
15th Feb, 2005 at 11:15:17pm
No the wheels will still be in the same place. What the right flanges will do is move the disc into the right place to line up with the caliper properly.
15th Feb, 2005 at 11:22:02pm
you sure tom?
Edited by turbodave16v on 15th Feb, 2005. On 17th Nov, 2014 Tom Fenton said:
15th Feb, 2005 at 11:30:51pm
I think you are right about the taper collar seat being more recessed into the drive flange, hence moving the face the wheel butts up to outboard (from the cv reference). But only moves it outboard a touch, from memory thinking about the difference in the flanges maybe 1/4"? But I also think that the flange itself is a bit thicker than the mini one, hence moving the face the disc bolts to inboard as well?
15th Feb, 2005 at 11:47:10pm
i bought the original car with them like that i just accepted it :) tonite i have learnd its wrong and im glad to be honest that i know now. Going to ask dan if i can have the flanges off his black metro turbo when hes taking the engine out Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
15th Feb, 2005 at 11:52:34pm
BTW wasn't having a dig I can see it looks like I am.
16th Feb, 2005 at 01:13:28am
oh yeah i know your not!!! your being really really helpfull on all my posts tonite i really am thankfull, you and turbodave always seem to bend over backwards to give me good advice, i can only get online a couple of nights a week. Usually it brakes down in the week, and ill ask the problems on the nights im online and fix it throguh the week :) I have a day off tomorow so im working on it all day :) Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
