| Home > Wanted > Any one in the sheffield area got a car transporter trailer i could borrow/hire on sunday? | |||||||
297 Posts Member #: 2276 Senior Member sheffield / derby |
2nd Sep, 2010 at 12:32:05pm
As title really, the trailer i normally use is already being used this weekend and i need to pick up my new toy this weekend! Can any one help? i would be most grateful cheers luke |
2nd Sep, 2010 at 01:06:57pm
WHat are you towing?
2nd Sep, 2010 at 07:46:15pm
On 2nd Sep, 2010 apbellamy said:
WHat are you towing? one of these!
its a clan crusader and only small im pretty sure it will fit on the trailer if a metro will. Things have changed a little in that i would need to borrow it on saturday if thats okay? Thanks Luke |
2nd Sep, 2010 at 07:54:06pm
Shouldn't be a problem, but best to get the wheelbase dimensions.
2nd Sep, 2010 at 08:05:27pm
On 2nd Sep, 2010 998turbomini25 said:
one of these! ![]() I want it....... I have a wet liner, Wills ringed, 998 engine waiting to go into one of these.... had it for years since I last had an Imp but the Clans never appear around my part of the world.
But I'll never throw the engine away just in case..... Schrödinger's cat - so which one am I ??? |
2nd Sep, 2010 at 08:30:03pm
Shouldn't be a problem, but best to get the wheelbase dimensions. The trailer is far from perfect, but tows OK. Twin axle with brakes on one axle. Used to be a caravan... full compliment of straps, break away cable etc Hi Andy trailer sounds absolutely fine. wikipeadia says the clans wheel base is 2,089 mm and the metro is 2250mm so it should be fine. also Im supposed to be meeting with John at some point to give him an oil drain hose, On 2nd Sep, 2010 Rod S said:
But I'll never throw the engine away just in case..... Unfortunately Rod this is not the one im collecting mine is a little more of a project!! i also have an imp that is used as a semi second car!! one day i dream of being able to afford a 998 engine BUT they go for crazy money at the moment!!
cheers luke |
2nd Sep, 2010 at 08:38:09pm
Andy will have to meet you for the trailer I think. Give him the drain I'll sort money out with him If something is worth doing, it's worth doing half of. |
2nd Sep, 2010 at 08:47:56pm
Andy/John
2nd Sep, 2010 at 09:04:28pm
Well the trailer lives nearer to John and he has the container key for the ramps etc, but the straps are at mine. You available tomorrow evening john? On 11th Feb, 2015 robert said:
2nd Sep, 2010 at 09:07:41pm
I can bob down to the yard in evening. I'll pick the rest of the tat up from yours after work. If something is worth doing, it's worth doing half of. |
2nd Sep, 2010 at 09:15:50pm
What time are you finishing? I'll be a bit late tomorrow. Straps etc are by the van's front passenger wheel. Garage is full of crap. You have a key... On 11th Feb, 2015 robert said:
2nd Sep, 2010 at 09:21:38pm
Trailer board? If something is worth doing, it's worth doing half of. |
3rd Sep, 2010 at 07:44:24am
