| Home > Help Needed / General Tech Chat > rocker cover clearance, 1.5 roller tip rockers | |||||||
![]() 78 Posts Member #: 8913 Advanced Member seaford, east sussex |
7th Sep, 2010 at 10:07:29pm
will i be able to use my standard rocker cover (one with breather outlet) with 1.5 high lift roller tip rockers? have heared that they can touch but when i put it on it seems fine, i turned engine over by hand and couldn't hear any tapping on the cover? anyone had any issues?
7th Sep, 2010 at 10:50:08pm
Some fit i beleve but ithers catch, some of the alloy ones do aswell but theres usually a bit of thickness on them to releve the inside.
8th Sep, 2010 at 08:04:17am
It will depend on things like has the head or block face been skimmed...
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
8th Sep, 2010 at 09:28:59am
I have a minispares alloy cover and had to take the sharp corners off the ROCKERS on no.1 and 8 on the pushrod end. 'Where does the engine go?' |
![]() 248 Posts Member #: 5007 Senior Member Crazyhill, Livi |
9th Sep, 2010 at 10:02:26am
I had the same issue as steve1275, I ended up using the original cover and everything was good.
"se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
9th Sep, 2010 at 11:09:12am
I removed a load of material from the inside of the cover to clear mine. In the 13's at last!.. Just |
9th Sep, 2010 at 09:23:14pm
will try a bit of blue tack to see how much clearance, head face has been skimmed flat hope 2 much hasn't been taken off as i want to use the original rocker cover.
