| Home > Help Needed / General Tech Chat > fuel tank mods | |||||||
11th Nov, 2003 at 04:15:02pm
I've got, and have used in fact, a std 7.5 gallon tank with a return crudly welded and seals into the top... AlexF |
28 Posts Member #: 66 Member |
11th Nov, 2003 at 06:48:52pm
Yeah I have done this, just run an inline enlarger from 8mm up to 10mm just before the pump about 2 inchs or so.
12th Nov, 2003 at 07:23:57am
I used the outlet off the metro tank and brazed that in so i could even use the piece of hose of the metro. Did the same with the return.
12th Nov, 2003 at 12:53:34pm
Yeah I have done this, just run an inline enlarger from 8mm up to 10mm just before the pump about 2 inchs or so. But i am running twin tanks. Rob thats exactly what I did, just wondering if there are likly to be any problems... 8mm is plenty for the the power i am running, but is the pump going to like it? alex AlexF |
12th Nov, 2003 at 01:17:24pm
Might be the reason why your pump sounded dodgy. They dont like restrcitions i dont think.
12th Nov, 2003 at 02:41:19pm
it could be, but that wouldn't explain why it only does it when its hot...
AlexF |
2nd Jun, 2004 at 12:16:30am
This post is from ages ago, just bringing it up again to ask if anyone found out if the inline enlarger for the pipe is ok?
3rd Jun, 2004 at 01:14:41am
i just used a piece of 8mm from the tank to the pump inlet and made it fit the 10mm inlet with lots of swearing, spit and grunting. :)
3rd Jun, 2004 at 01:19:41am
OK thats great, thats what ive done too Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
![]() 265 Posts Member #: 68 Senior Member Coventry |
3rd Jun, 2004 at 08:23:00am
Do it proper! its easy enough.... i posted this in the other thread....
Edited by mini-marauder on 3rd Jun, 2004. Sooperdooperturbocooperexpertengineering! |
3rd Jun, 2004 at 08:49:01am
I haven't sorted mine properly yet....
AlexF |
102 Posts Member #: 155 Advanced Member |
14th Jun, 2004 at 09:57:11am
alex ! |
14th Jun, 2004 at 07:59:30pm
ive just fitted a mpi tank this weekend easiest way of all i think if you can find one!
19 Posts Member #: 301 Member |
17th Jun, 2004 at 09:23:29pm
you can take the pipe from a rover SD1 tank it has a good filter on it and is just the rite size |
