Home > Show Us Yours! > superlight splitrim refurb
welshdan
Member #: 1111
s wales
hi, i picked up a set of superlight splitrim alloys some time ago for my car as featured in my build thread.
they wheels werent in too bad a shape, but starting to look tired and showing their age.
i knew this would be a bugger of a job, but bit the bullet and started on them just prior to the weekend
this is the wheels once we had picked them up - they dont look too bad in the pics, but in reality were a bit rough
got the tyres removed, but made a start polishing the outer rims prior to this
yoko semi slicks going on the front two. will be using yoko a539s on the rear
original nasty black bolts ...
removed
new m4 stainless dome top bolts to replace. will polish these up on polishing wheel befrore fitting
the worst part was removing the sealant once the rims where split apart. 3 down, one to go.
outer rim
wheel centre piece.
three pieces of the wheel placed together.
so the plan is to strip and clean the 4th wheel.
hopefully i can get this done this week. the centre of the wheels i will paint vw black magic to match the colour scheme of my car.
the outers i will highly polish
i have some old stock john cooper garages centre caps to fit once done.
as stated, the bolts will be changed. i also am going to fit some richbrook flush fit valves.
this has been short but sweet, will keep updated with the progress.
also i believe i have to re-seal the rims with normal silicone (have read this somehwere on this site). also have to look to see the torque setting sof the bolts, which i know has been discussed previous here. will have to get searching. cheers
Edited by welshdan on 12th Sep, 2010.
sturgeo
Member #: 1778
Northants
What rating are those bolts?
welshdan
Member #: 1111
s wales
not sure, but they are quality rs items. with 18 of them per rim, it will be ok.
nutter driver
Member #: 47
Not very sunny swanage
not sure silicone is the right thing to use, sure you can get some propper wheel stuff.......
looks great otherwise!!
Nick
Member #: 154
Midlands
i know when we did keans on his nissan we used normal silicon, i'm sure they were M6 bolts though, M4 seem a bit small to me?
welshdan
Member #: 1111
s wales
i think its m4 off the top of my head. - ordered the bolts a long time ago. though they fit perfectly where the originals were fitted. following searches, quality silicone seems to be the best thing to seal the rims.
i didnt think stainless even had a high tensile rating
other than that they look good
welshdan
Member #: 1111
s wales
my brother has a set of revo splitrims. they were fitted with stainless bolts from new.
Stainless bolts are not up to the job. What you want are plated cap screws grade 10.9 minimum.
An A2 or A4 class 80 stainless screw is equivelent 8.8 carbon steel. There are A2 or A4 class 100 whih are equivelent 10.9 carbon steel. I would give RS a call and see if they can find out what strength class their screws are.
Also, I doubt very much those scres are M4. That is just daft. They look more like M6.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Tom. I'm intrigued.
Purely for debate, surely if you're gonna exceed the UTS of stainless on 18 bolts put together then the ali wheel must be fubar anyway well before the bolts can exceed their loading. Or am I missing something here ? Is there a shock loading to consider ?
I've used A2 stainless M6 socket allen caps previously on a set of MB 13x7 alloys before. This was on a road car, not a racer.
Certainly more aesthetically pleasing and easier to keep corrosion at bay than plated HTS bolts.
Richard.
It is more work hardening in stainless that then causes it to go brittle and fail well below its rated tensile strength.
That is my understanding of it in any case.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Oh.......
And great job on the wheels they look fab mate !
Rich.
turbominivanman
Member #: 1504
Westbury, Wiltshire
So, if A2 st st does get used, would it be worth undertaking a more frequent bolt torque check or even a complete bolt replacement at say, a yearly interval ?
silicon works fine however iirc stainless bolts dont have the shear strength
Are those 12" or 13"??
look like 13's with the bridgstones on in the first pic
Rick.
Couldnt you be more adventureus and do th centres a different colour.lol
A common misconception, even amongst some of the engineers I have worked with, is that stainless bolting is "stronger".
The only thing I would add to Sprocket's figures above is that in my experience the most common stainless bolting, A2, is usually only class 70 which is not even as strong as a plain high tensile (8.8) steel bolt and about half the strength of a 10.9
The other issue with stainless, especially A2, is it becomes embrittled in mildly corrosive atmospheres (ie, salted British roads) especially if it is in contact with a dis-similar metal.
welshdan
Member #: 1111
s wales
thanks for the input re the bolts. they will be bolted back together with what i have, but i will look to change them in the future.
the wheels are 7x13, have a bit of a wild offset on them. they stick out just past sportspack arches (though that is with the sportspack spacers on there).
i did think about going for either gunmetal, gold or the black centres. i really think the black centres will suit the car though.
Coupe
Member #: 2178
Leyland, Lancs
That offset looks perfect to me. I certainly wouldn't say it was wild.
not wanting to piss on your fire, but I'd change the bolts to a grade you know what is, I've seen a few nasty miglia crashes due to the bolts failing, instant tyre deflation, not like a normal puncture.
Do you want to risk scrapping your minis for £30 worth of bolts?
johnK
Member #: 690
Norfolk
Its probably the last sort of debate you wanted to open on your wheels - look very nice by the way! but what Tom, Jim and others say is true - S/steel is not a good use for wheel bolting, the problem with "re-torquing" is you are yielding the bolt each time you do this - not a good idea on a brittle bolt or 12.9 grade, 10.9 can cope with a little re-torquing, 8.8 a little more - but you'll not find quality cap screws in 8.8 grade. Beware also zinc plated 12.9 cap screws as they will suffer "hydrogen embrittlment" and snap in a similar manner to s/steel - unless you have a conformance cert from the supplier to say they have been treated for embrittlment - read expensive.
again very nice wheels - be worth spending a little to ensure they stay in company with the car!
JK
If Carling made Mini engines
Ben H
Member #: 184
Melton Mowbray, Pie Country
The other thing to consider is that stainless and aluminium make quite a nice battery. Much better off with mild.
http://www.twin-turbo.co.uk
welshdan
Member #: 1111
s wales
i have made a bit more progress with this. split and cleaned the last wheel. tidied the rears up
got them in primer yesterday.
the cast centres were shocking, took quite a bit or prep to take out the roughness etc. hopefully the topcoat will look ok.
got my paint in the week. its vw black magic pearl, same as the roof on my car.
going to prep and get the black on this afternoon.
welshdan
Member #: 1111
s wales
freshly painted. will get some more pics when back together and on the car.
dan
