| Home > General Chat > Bespoke Titanium Part Ideas | |||||||
![]() 568 Posts Member #: 1200 Post Whore Bristol |
13th Sep, 2010 at 09:43:14am
Hi All,
![]() 1547 Posts Member #: 2727 Post Whore Bicester |
13th Sep, 2010 at 10:14:15am
Sounds interesting Gaz, just wondering how the mechanical properties of the finished product compares to machining/casting more traditional methods? 1972 998 TURBO SLEEPER |
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
13th Sep, 2010 at 10:42:52am
Should be better, isnt that sort of thing able to create 100% density parts? In boost we trust |
13th Sep, 2010 at 10:50:42am
13th Sep, 2010 at 11:17:02am
it sounds like it its very similar process to SLS and DMLS. think your right stig. 1972 998 TURBO SLEEPER |
13th Sep, 2010 at 11:29:34am
yep it is laser sintering, you can make fully functional mechanical parts even a gear set! The surface finish can be a bit like cast parts and they do need additional secondary machining depending on the requirements, ideally i would like to make a functional component rather than a shiny ornament bolted on. |
13th Sep, 2010 at 11:35:05am
what a great place to work, how do you get any work done id spend all day dreaming up stuff to make lol. dont suppose the company has a website it could be useful for work.
13th Sep, 2010 at 11:46:00am
On 13th Sep, 2010 Joe C said:
Gearcase! +1 ( or dizzy blanking plug )
Edited by Brett on 13th Sep, 2010. Yes i moved to the darkside |
13th Sep, 2010 at 12:31:49pm
i would look at the heavy parts, radius arms, gearscase posss a subframe?
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
13th Sep, 2010 at 12:56:20pm
John Holmes gear knob internationally known as "big" swede |
13th Sep, 2010 at 01:10:45pm
whats a john holmes gear knob??
![]() 4633 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
13th Sep, 2010 at 01:24:38pm
On 13th Sep, 2010 pickmeup said:
whats a john holmes gear knob?? Ha ha !!!
13th Sep, 2010 at 01:41:50pm
13th Sep, 2010 at 01:47:11pm
you read my mind Vegard 1972 998 TURBO SLEEPER |
3594 Posts Member #: 655 Post Whore Northern Ireland |
13th Sep, 2010 at 05:42:57pm
most of the above is obvious stuff like con rods.
13th Sep, 2010 at 06:06:49pm
On 13th Sep, 2010 stevieturbo said:
most of the above is obvious stuff like con rods. Making something that would be very useful, as well as cool would make more sense. Gearcase would be a good one for sure. Or perhaps could you design a part to strengthen the existing gearcase ? Then the design might also have some commercial value too. John Holmes gear knob. internationally known as "big" swede |
![]() 9326 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
13th Sep, 2010 at 06:43:57pm
Mistakenly i just googled john holmes gear knob, had no luck, so then tried 'John Holmes'.... |
388 Posts Member #: 442 Senior Member Manchester |
13th Sep, 2010 at 07:03:29pm
Valves, valve springs oooo cylinder head..... |
![]() 1014 Posts Member #: 238 Post Whore essex |
13th Sep, 2010 at 07:14:54pm
i work with a guy called john holmes... ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
13th Sep, 2010 at 07:44:31pm
On 13th Sep, 2010 adam1330 said:
i work with a guy called john holmes... did your ass hurt afterwards?? anyhoo cylinder head is an idea but is it really worth doing with all the 7ports about? |
13th Sep, 2010 at 08:18:00pm
a verto flywheel? might appeal to the lads running the modded clutches? "Turbo's make torque, and torque makes fun"
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
13th Sep, 2010 at 11:36:12pm
anyhoo cylinder head is an idea but is it really worth doing with all the 7ports about? Yes Joe C's cylinder head !!!
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=347050 |
13th Sep, 2010 at 11:36:45pm
Rocker pillars, 3rd motion bearing retainers, 4 bolt centre main, the rod change bit that sticks out the box (and the bit round it),
13th Sep, 2010 at 11:39:18pm
PMSL,
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=347050 On 28th Aug, 2011 Kean said:
13th Sep, 2010 at 11:40:40pm
some new fangled front hub? |
