| Home > Help Needed / General Tech Chat > gearbox problem | |||||||
100 Posts Member #: 344 The Royal Mail lose every parcel I ever send.....and I am a TWAT |
17th Feb, 2005 at 06:45:13pm
hi again i was just out in my turbo came round a bend and the steering went stiff then as i pulled in to let a car through i went to set of and there is no go now it goes in 1st 2nd 4rth rev but not 3rd but iven in 124 i let the clutch out and there is no movement any ideas |
17th Feb, 2005 at 06:51:09pm
echhhhhhhhhhhhhhhh...........
421 Posts Member #: 245 Senior Member |
17th Feb, 2005 at 06:54:57pm
yep diff pin/mainshaft. happy days. |
17th Feb, 2005 at 07:05:05pm
ahhh is it easy to fix or is it engine out time
17th Feb, 2005 at 07:12:18pm
was just talking to pot dan about you. he said it still drove in 1,2,4 thats why i didnt think it was the diff pin! lol!
17th Feb, 2005 at 07:12:53pm
But you can do these with the engine in on metro cant you? Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
17th Feb, 2005 at 07:33:44pm
are the mg and turbo diff pins the same |
17th Feb, 2005 at 07:38:36pm
if it is the diff pin replace it with a competition
17th Feb, 2005 at 07:44:06pm
you got any ideas of where i can get one
17th Feb, 2005 at 07:49:02pm
any of the big mini dealers.check the mags. |
17th Feb, 2005 at 09:37:00pm
ive havnt had a decent comp diff yet which has been better than a genuine rover one.
18th Feb, 2005 at 10:01:46am
also dont forget to replace the planets, not just the pin. |
18th Feb, 2005 at 11:08:57am
right lads got my car on ramps ready to remove the diff just draining oil at the mo can anyone give me some tips on wat to do and wat not or should i just rip the bloody thing off
18th Feb, 2005 at 11:27:00am
mettyturbos first thread stated that it did not drive but he could engage the gears except 3rd
Edited by BENROSS on 18th Feb, 2005.
18th Feb, 2005 at 11:54:08am
Hes only just got the engine back in too :(
18th Feb, 2005 at 12:10:34pm
some of the later metros were glued together with that hideous blue stuff hylomar.
18th Feb, 2005 at 07:58:58pm
good check is, remove the drive shafts as surgested, then grap each output shaft with your hands and then push together and twist in opposite directions if it is nice and smooth then i may sugest it could be somthing a bit more than a smashed diff. as it will go in 3 gears and not in 3rd sugest not a diff as it would be the same for allgears (well in theory any way).
19th Feb, 2005 at 11:47:56am
right got the diff of its tottaly disintagrated but all the gears have gone into my gear box i dont think this is looking good i think engine rebuild number 3 is on the cards |
19th Feb, 2005 at 12:34:03pm
sorry to hear that buddy well opt for a minispares 4 pin diff next time metty
