| Home > Help Needed / General Tech Chat > block cleaning help | |||||||
![]() 334 Posts Member #: 7169 Gobshite that posts wank videos. Somerset, UK |
14th Sep, 2010 at 09:33:42am
Hi all,
Gaball said:
Motorsport Engineering Student Project Car 1293 Turbo Mini (on a student budget) On 7th Oct, 2010 apbellamy said:
Carbon but plug? |
14th Sep, 2010 at 12:20:04pm
Some machine shops have an acid dip
14th Sep, 2010 at 01:05:57pm
It wasn't me that had the engine at this point was bought out of the car,
On 14th Sep, 2010 almichie said:
Some machine shops have an acid dip Tank, but I'm Not sure if that'll shift rust. There should be no rust in the waterways if you used the correct dose of coolant (it's an oxide inhibitor as well as antifreeze) Gaball said:
Carbon but plug? |
14th Sep, 2010 at 08:15:17pm
Can you post some pictures? Surface rust is no real surprise in the coolant circuit. |
14th Sep, 2010 at 11:05:23pm
Especially as you cheap Englanders never use anti freeze... On 13th Jul, 2012 Ben H said:
14th Sep, 2010 at 11:10:03pm
Yea ill get photos on 2morrow
Carbon but plug? |
15th Sep, 2010 at 12:09:55am
The water pump is next to Cylinder 1 the clutch is nex to cylinder 4 Own the day
15th Sep, 2010 at 07:22:48pm
right some pictures up,
Carbon but plug? |
15th Sep, 2010 at 07:27:25pm
i spoke with my machine-ist last time i was down with the block, there acid bath removes everything
Yes i moved to the darkside |
15th Sep, 2010 at 07:31:16pm
I was impressed with POR's metal ready when I sealered my fuel tanks,
15th Sep, 2010 at 07:44:14pm
how much was that?
On 15th Sep, 2010 Brett said:
i spoke with my machine-ist last time i was down with the block, there acid bath removes everything i asked specifically about the waterway rust he said absolutely they have a fook off basket as much as i could fit in for a fixed price Gaball said:
Carbon but plug? |
15th Sep, 2010 at 07:53:31pm
I wouldn't mind about that. That's nothing. As long as it isn't flaking off, don't worry. On 13th Jul, 2012 Ben H said:
15th Sep, 2010 at 08:22:53pm
I'm with Vegard, that's fuck all for a cast iron block that's been left to dry out.
15th Sep, 2010 at 08:38:51pm
If i give him a blast out and a soak in Diesel and Jizzer will shift the most of it?
On 15th Sep, 2010 Rod S said:
I'm with Vegard, that's fuck all for a cast iron block that's been left to dry out. If there is any loose stuff, blow it out with a pressure washer but otherwise leave it alone and use antifreeze from now on (because of the inhibitor it contains). Be very wary of so called chemical cleans or acid washes....... Often they use a derivative of sodium hypochlorite (actually alkaline, not acid) which can do serious damage to older cast iron through de-graphitisation (removal of the carbon, which is an essential part of cast iron, from between the grain boundaries). If it's mechanically sound, just remove any loose stuff and leave well alone IMO. Gaball said:
Carbon but plug? |
15th Sep, 2010 at 09:19:29pm
Anti-freeze? Isn't that keeping the car in the garage overnight On 14th Sep, 2010 Vegard said:
Especially as you cheap Englanders never use anti freeze... |
15th Sep, 2010 at 09:26:23pm
I'm with Vegard, that's fuck all for a cast iron block that's been left to dry out. If there is any loose stuff, blow it out with a pressure washer but otherwise leave it alone and use antifreeze from now on (because of the inhibitor it contains). Be very wary of so called chemical cleans or acid washes....... Often they use a derivative of sodium hypochlorite (actually alkaline, not acid) which can do serious damage to older cast iron through de-graphitisation (removal of the carbon, which is an essential part of cast iron, from between the grain boundaries). If it's mechanically sound, just remove any loose stuff and leave well alone IMO. i didnt quote the price because i was quoted "off the books" but would guess about 25-30 quids although Rod has me thinking, my block is not bad at all i might just give it a good bath
15th Sep, 2010 at 10:35:54pm
What I would do, is to countersink the holes for the waterpump. On 13th Jul, 2012 Ben H said:
15th Sep, 2010 at 11:57:08pm
On 15th Sep, 2010 Vegard said:
What I would do, is to countersink the holes for the waterpump. you've got me confused V countersink what bit? Yes i moved to the darkside |
