| Home > Technical Chat > spi and mpi cars | |||||||
17th Feb, 2005 at 11:50:48pm
as there injection wheres the fuel swirl pot? Crystal Sound Audio said:
18th Feb, 2005 at 12:02:59am
not every car has to have one! On 17th Nov, 2014 Tom Fenton said:
18th Feb, 2005 at 02:16:39pm
there isnt :)
AlexF |
19th Feb, 2005 at 12:43:01am
i thought all injection cars had them as theres no float chamber to stop starvation Crystal Sound Audio said:
208 Posts Member #: 438 Senior Member London |
19th Feb, 2005 at 12:29:08pm
Don't think you need one if the petrol tank is sufficiently baffled.
19th Feb, 2005 at 05:17:38pm
is there any difference in the pumps?
20th Feb, 2005 at 11:47:20am
Wouldn't have thought there'd be that much difference, they both need to pump higher pressure than a N/A carb system. |
21st Feb, 2005 at 02:23:22pm
MPi pump has a slightly higher pressure than the SPi pump - they look visually identical. Not easy to tell them apart! On 17th Nov, 2014 Tom Fenton said:
22nd Feb, 2005 at 10:12:21am
You dont need a swirl pot as the fuel rail will hold sufficient AlexF |
22nd Feb, 2005 at 05:28:40pm
The fuel delivery pressure is much higher on injected engines, so theres always more fuel in the rail than the injectors can possibly flow. alex I think you're missing the point Alex? Once an injector pulses, the pressure in the fuel rail drops - and this would happen in microseconds at a decent rpm. I believe the mini doen't have a baffle because of the shape of the tank - it's more vertically oriented than a conventional tank - so if the pickup is near the bottom, only if it's very close to empty will fuel starvation be an issue. On 17th Nov, 2014 Tom Fenton said:
22nd Feb, 2005 at 05:34:40pm
A swirl pot wont help with fuel rail pulsing....
AlexF |
22nd Feb, 2005 at 05:37:48pm
I thought the point of a swirl pot was to de-airate fuel returning from the fuel rail to the tank?? I thought the problem comes from fuel spurting back into the tank in an uncontrolled manner leading to airated fuel, and when this gets pumped through to the engine the air causes leaning out/misfire??
22nd Feb, 2005 at 07:39:23pm
22nd Feb, 2005 at 10:13:09pm
The idea of a swirlpot in a fuel system is to make sure that the fuel rail NEVER runs dry.
Edited by turbodave16v on 22nd Feb, 2005. On 17th Nov, 2014 Tom Fenton said:
