| Home > Technical Chat > Magneti Marelli crank sensors | |||||||
16th Sep, 2010 at 10:29:18pm
hi
My build thread..
16th Sep, 2010 at 10:59:10pm
Check with JohnK I run a supercharger and I don't care the TB is on the wrong side.
203 Posts Member #: 1734 Senior Member Lancaster |
16th Sep, 2010 at 11:46:57pm
yes it does...albeit is wired backwards |
17th Sep, 2010 at 05:55:44pm
what do you mean manifold??
My build thread..
17th Sep, 2010 at 06:58:19pm
Magneti Marelli crank sensor from what car ???
1425 Posts Member #: 690 Post Whore Norfolk |
17th Sep, 2010 at 07:41:25pm
The SC trigger kits use the SEN8D Marelli sensor
If Carling made Mini engines
18th Sep, 2010 at 12:35:37am
I have found that the send8d sensor seems to work fine if wired (only 2 wires) the opposite way round than the standard EDIS (ford fiesta/escort) ones. Well it did for me. |
18th Sep, 2010 at 09:12:16pm
Used a Fiesta crank sensor and pulley mounted trigger on my 1400 SPi with standard Rover ECU no problem. I see no problem. Polarity is just a technicality On 26th Oct, 2004 TurboDave16v said:
