Home > Help Needed / General Tech Chat > Trigger Wheel Fell Off
minimized
Member #: 1503
Long Island, New York, USA
This past 10 days of Mini problems have been a $#^(67. Solve one go on to the next failure etc etc. .
I re-torqued the head today, reset the VR Sensor Gap to .030 and started the engine, no problem.
While verifying the .larger .030 gap resolved the backfiring problem by running the engine up to hi revs (which it did),
The blasted steel Trigger wheel just flew off the aluminum pulley!!! I always wondered if the 2 small loctited screws were sufficient??
Would appreciate inputs and maybe a better mounting system for the Steel Trigger to the Aluminum Pully.
Thanks
minimized
Member #: 1503
Sorry I mean 3 screws not 2. Thanks
tadge44
Member #: 2500
Buckinghamshire
Thats worrying as I have 4 4mm screws holding mine and they are loctited too. Did you use HT screws ? did the screws break or just come loose ?. Maybe the steel trigger wheel is a bit heavy and clunky ?.
Do you have a picture, it would be easier to try to understand if not.
When you say you have an aluminium pulley, do you have a crankshaft damper on there?
Yes, a picture would help.
One of mine is held on by 3 off 6mm screws but I machined a small step on the back of the pully first which centralises it and carrys any radial loads so the screws (theoretically) do very little.
minimized
Member #: 1503
Thank,
I never bothered or learned to keep my pics online. I guess I will make that my project this weekend.
cheers
sturgeo
Member #: 1778
Northants
Why not use a TF trigger? suppose postage might be pricey to the states but you'll never have to worry about it again.
minimized
Member #: 1503
What is a TF trigger????
minimized
Member #: 1503
I have a supercharger , no Turbo.
How would I use that?
