| Home > General Chat > Cam timing brain fart!!!!! | |||||||
124 Posts Member #: 1126 Advanced Member peterborough |
17th Sep, 2010 at 01:02:31am
Im gettin 105 degs an need 108, my brain hurts!!!
17th Sep, 2010 at 01:09:56am
Im leaning towards 6 but what to allow for stretch???? |
17th Sep, 2010 at 01:17:16am
Figured it.... gonna go for a 5 = 2.5 at crank which will stretch to 3 :0) |
17th Sep, 2010 at 07:56:23am
you only need to allow for chain streach on a new chain surely. Or is the chain a bit elastic when the engine is runing? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
17th Sep, 2010 at 05:57:16pm
are you sure your getting 105
Edited by BENROSS on 17th Sep, 2010.
18th Sep, 2010 at 11:40:37am
Hmmmmm? Think I'm gonna check it over again! It's a phase 2 from avonbar (repro) and a new chain and light steel gears from ms but with all the numbers going on it was getting a bit emotional :).
18th Sep, 2010 at 05:46:08pm
time the cam in at 108 deg on the crank from TDC. on the piston
18th Sep, 2010 at 06:15:25pm
And don t try to find the full lift point just watching the DTI - note the degrees at ,say, 5 thou before and again at 5 thou after and then split the difference in the degree figures to set the maximum lift point. Because there is always a bit of dwell on the nose of the cam at full lift it is difficult to establish it otherwise. |
