| Home > Help Needed / General Tech Chat > timing cover | |||||||
![]() 871 Posts Member #: 2590 Post Whore Croydon |
18th Sep, 2010 at 06:41:52pm
i know that the timing cover will need to be modified in means of removing the breather but does it not need to have a breather as wouldnt the pressure blow the timing cover seals all the time? |
![]() 1014 Posts Member #: 238 Post Whore essex |
18th Sep, 2010 at 08:27:37pm
why do you want to remove the breather? ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
18th Sep, 2010 at 08:47:46pm
the only modding you would need to do to a cover is modify it on the INSIDE for dual timing chains. if your breather is hitting the fan then all you have to do is try and crush it a bit? |
18th Sep, 2010 at 11:39:17pm
Or space it out a little, mine clears by a fag paper! Own the day
19th Sep, 2010 at 10:31:34am
On 18th Sep, 2010 Mr Joshua said:
Or space it out a little, mine clears by a fag paper! be careful with that mr joshua, as the fan spins it flexies slightly, i managed to wreck 2 radiators and destroy 2 fans after contact with the breather pipe. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
19th Sep, 2010 at 10:49:39am
sorry should really illeterate a bit i have a supercharger set up but the belt i am using does not clear the breather on the timing cover |
19th Sep, 2010 at 04:00:12pm
should really have put that in my first post |
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
19th Sep, 2010 at 08:04:25pm
how about chop it off and block up the hole, then run a hose from a more convenient point on the cover to a catch tank? |
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
19th Sep, 2010 at 09:30:01pm
Innos had the breather on the backside of the front plate (where it overhangs the block on the rear of the engine) [X] nail here for new monitor |
19th Sep, 2010 at 09:50:50pm
You can loose the canister and just fit a filter/catch tank as long as you are not feeding back to the carb. In the 13's at last!.. Just |
20th Sep, 2010 at 08:02:16pm
well i just had the timing cover off to see what i can do about it as the sc belt will not be able to pass the charger,
21st Sep, 2010 at 11:48:07am
Just get a 998 A+ timing cover. no breather as standard On 11th Feb, 2015 robert said:
21st Sep, 2010 at 12:55:01pm
will pressure not build up and blow the timing cover gasket then? |
21st Sep, 2010 at 01:02:39pm
Not if you have adequate breathing elsewhere on the engine. If something is worth doing, it's worth doing half of. |
21st Sep, 2010 at 01:18:10pm
Innocenti Cooper 1300: http://img832.imageshack.us/img832/7963/in...tientlftung.jpg [X] nail here for new monitor |
21st Sep, 2010 at 01:24:29pm
yet another well thought out change on the inno's! On 28th Aug, 2011 Kean said:
21st Sep, 2010 at 01:26:38pm
That looks like it would be a PITA with a turbo. If something is worth doing, it's worth doing half of. |
