| Home > Beginners Tech > Suitability of Standard MPI Fuel Pump for Turbo? | |||||||
![]() 3 Posts Member #: 9068 Junior Member Lutterworth, Leics, UK |
20th Sep, 2010 at 12:35:39pm
I'm fitting a standard MG Metro turbo setup to my (non turbo) MG engined Mini and I gather I need a fuel tank with a return pipe for the pressure regulator.
20th Sep, 2010 at 12:51:49pm
its fine! |
20th Sep, 2010 at 02:10:04pm
thats what i intend to use so hopefully yes |
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
20th Sep, 2010 at 02:36:59pm
how about a more powerfully engine? I was told the mpi or spi tank would be good up to about 100bhp much more and you would need a larger capacity pump? |
20th Sep, 2010 at 02:54:10pm
The mpi pump will be fine the spi used a lower pressure pump (now discontinued anyway). |
20th Sep, 2010 at 02:57:57pm
i know of the mpi pump being used at 168 odd hp with no issues.
Edited by Joe C on 20th Sep, 2010. On 28th Aug, 2011 Kean said:
20th Sep, 2010 at 05:07:22pm
i had 168 with standard pump Crystal Sound Audio said:
![]() 825 Posts Member #: 2208 Post Whore Essex |
20th Sep, 2010 at 07:35:13pm
i may be wronge but iwve been informed that mpi is good up to 15psi of boost |
20th Sep, 2010 at 07:35:50pm
so spi it a no no and mpi is fine? |
20th Sep, 2010 at 08:36:42pm
this might help
20th Sep, 2010 at 10:05:30pm
I thought that you need 3 psi above maximum boost. So if you want 1 bar (14.7psi) you need 17.7psi of fuel pressure for correct delivery into the carb if your using a carb! I'm going to try the spi tank as it's good to 1.1 bar (17psi ish) and use 7-12 psi of boost... On 7th Nov, 2011 apbellamy said:
21st Sep, 2010 at 07:42:32am
Iirc the SPI pump gives about 15psi so is suitable for about 10psi, the MPI is about 3bar I think ? So obviously more than enough. |
22nd Sep, 2010 at 11:32:51pm
Thanks for the replies everyone, looks like the MPI fuel pump is indeed a go. I am thinking of running something like 10-12 PSI of boost so I think it will be more than adequate.
