| Home > Help Needed / General Tech Chat > Advice needed for setting up gaz dampers | |||||||
301 Posts Member #: 2480 Senior Member Swindon |
21st Sep, 2010 at 11:00:38am
Ive brought and fitted some gaz dampers to help tidy up the under bonnet area of the car (spax ones were held together with rust!) but have no idea what to set them to. It says on the instructions that turning the dial all the way anti clockwise is softest and harder clockwise. It also said to not over adjust the dampers as they may fall apart! So i turned the dial anti clock untill it stopped which was fine, then turned it clockwise hoping it would lock at some point, which it didnt. I counted 25 clicks then thought i better stop. So both dampers have been set 5 clicks from the stop point when turned anti clock. Will this be firm or have made hardly any difference from the soft setting? How many clicks are there!? I dont want to over do it and break the dial thing but i do want it to be quite firm. Any help with this long winded question would be great! Thanks feature=mhum |
21st Sep, 2010 at 11:10:00am
Start at 4 on the back and 8 or 9 on the front and work up.
21st Sep, 2010 at 12:29:58pm
brilliant. I will try that. Thanks joe feature=mhum |
1050 Posts Member #: 764 Post Whore Staffordshire |
21st Sep, 2010 at 12:34:08pm
I believe they have 32 clicks available.... on the mighty we were running it around the 15 mark, so as already said go with a fig between 5 and 10. |
21st Sep, 2010 at 12:42:05pm
I think my rears are set to 8. It's not a nice ride at the moment. In the 13's at last!.. Just |
21st Sep, 2010 at 12:43:09pm
like stuffing an anorexic... On 28th Aug, 2011 Kean said:
21st Sep, 2010 at 01:50:52pm
im on 3 front 0 back , and fast use 5 front 3 back . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
21st Sep, 2010 at 01:55:06pm
Quite a few peeps seem to use these. Whats your opinions If something is worth doing, it's worth doing half of. |
