| Home > Help Needed / General Tech Chat > carb and needle recommendation | |||||||
![]() 825 Posts Member #: 2208 Post Whore Essex |
21st Sep, 2010 at 07:46:32pm
right, im having a little trubble with running lean.
21st Sep, 2010 at 08:24:10pm
first off turning the screw will do jack shit at anything much above idle,
21st Sep, 2010 at 08:35:04pm
hi mate, was thinking of calling ya, thought i might put it on here first as i allways call you lol!
On 21st Sep, 2010 Joe C said:
first off turning the screw will do jack shit at anything much above idle, how is you pump & feed plumbed? what make you think its running lean? |
21st Sep, 2010 at 09:42:14pm
STD feed, 8mm return.
In the 13's at last!.. Just |
21st Sep, 2010 at 09:46:32pm
hum,
21st Sep, 2010 at 09:50:31pm
It's worth trying some heavier oil to.
21st Sep, 2010 at 09:56:22pm
cool, im using 20/50
On 21st Sep, 2010 Turbo Phil said:
It's worth trying some heavier oil to. I have standard needles if you need one. :) Edited by wintersurferuk on 21st Sep, 2010. |
21st Sep, 2010 at 10:31:07pm
Get a wide band hooked up, it will take out the guess work and save your engine! |
21st Sep, 2010 at 10:42:14pm
Or get it to uncle Ray's! In the 13's at last!.. Just |
169 Posts Member #: 748 Advanced Member Cirencester, Gloucestershire |
21st Sep, 2010 at 10:42:51pm
Either that or get it on the rolling road and set it up properly, saves alot of time! Most garages will profile the needle for you... Try Atspeed in Essex, that's where mine was set up. 1310 - Supercharged 16v Twin Cam - 190BHP - SC Built.
21st Sep, 2010 at 10:48:05pm
stuff two springs in and see if it has the right kind of effect before you spend out on a spring.
22nd Sep, 2010 at 09:38:21am
Anyone got a spare spring? In the 13's at last!.. Just |
22nd Sep, 2010 at 11:06:02am
lol!
22nd Sep, 2010 at 11:13:09am
What sort of boost are you running?
22nd Sep, 2010 at 11:27:51am
I'm running 6psi at the moment. Haven't got a spare spring. Just don't want to get to the rollers and be let down by a crap spring.
22nd Sep, 2010 at 12:20:48pm
I think we have the Avonbar high boost needle in the van running about 15-16 psi. AFRs are pretty good for most situations.
22nd Sep, 2010 at 12:45:24pm
At 6psi, i'd keep the standard 8oz spring.
