| Home > Help Needed / General Tech Chat > grub screws m14 | |||||||
![]() 190 Posts Member #: 8935 Advanced Member netherlands |
22nd Sep, 2010 at 10:17:03am
finaly i found some m 14 grub screws for drydecking project, But they are m14X2 would this thread be to wide to seal it properly with loctite??
22nd Sep, 2010 at 10:24:24am
Can you not use a high temp apoxy resin rather than loctite? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
22nd Sep, 2010 at 10:37:22am
1/4" BSP taper plugs would be better.
22nd Sep, 2010 at 10:43:28am
We've used these for the oil galleries (m14 x 1.5):
22nd Sep, 2010 at 10:49:01am
M14 X 2 is standard ISO, anything finer will be hard to come by in a grubscrew/plug - a compressed air specialist might stock them though as air fittings often use metric fine threads.
Edited by Rod S on 22nd Sep, 2010. Schrödinger's cat - so which one am I ??? |
22nd Sep, 2010 at 11:00:03am
thank for replies guys... but what do you mean with "paralel"? |
22nd Sep, 2010 at 11:09:03am
On 22nd Sep, 2010 clubbie70 said:
thank for replies guys... but what do you mean with "paralel"? A normal thread, like a nut and bolt, is parallel - same diameter all the way along so the nut runs the full length of the bolt. With pipe joints, plugs, etc., it is common practice to use a tapered thread on one or both of the male/female threads. A tapered thread does just that, it tapers away from the correct size so locks up as it is screwed in. Note - it still needs sealing, but will mechanically lock up at a certain point. Trouble is, unless you do it very accurately you won't know where it is going to lock up so may have to machine bits off afterwards. Schrödinger's cat - so which one am I ??? |
