Home > Help Needed / General Tech Chat > timken idler questions
clubbie70
Member #: 8935
netherlands
hi, got a timken sc idler. took it appart today to clean bearing.
I noticed that i could move the outher bearing shell around inside the gearwheel on bot sides??
ques thats not normal, coz normaly you have to use hammer or press to get them in, like a wheel bearing.
2. do the gearbox and transferhousing need modifying for use of such a idler?
3. i thought the space between the bearing and the transferhousing are a little big, diam of the bearing is 34,6 mm
thanx
Scruffy
Member #: 328
Seaford Rise, South Australia
No bearing race should spin or move
No mods needed other than bearings removed
Should fit snuggly or it is wrong!
On 5th Sep, 2011 Vegard said:
clubbie70
Member #: 8935
netherlands
MMM mabey i chasing ghost here.... but if i measure a brand new torrington idler bearing its 34,8 mm. I need a little hammer to pressfit them in the gearbox and transferhousing ( wich are both 34,60mm). The timken idler measures 34,53 on both sides. In my opinon it has a loose fit, would it mean the timken idler is gone ( its a used one) . or would the transferhousing prees it hard enough against the gearbox in the end|??? *Confused*
in short, the used timkin is fubar ( get a new one)
clubbie70
Member #: 8935
netherlands
thanks thought so.... last point of advice.
I have a brand new jk idler gear with torington bearings.. Use that one or get a new timken ???
i doubt the jk ider would work unless the primary and input gears are jk aswell
clubbie70
Member #: 8935
netherlands
sorry prim and input are also new....were bought as a set::
just would like to know if the timken was MUCH beter??
timken are regarded as very good bearings but if you have a new set of jk drops and bearings just whalop them things in, jk are regarded as one of the best and thus i would presume the bearings are upto scratch
the bearing outer! race is............ an interference fit in the gear. if the bearing is ok and i would say there is a good chance it is, i would bearing fit " high strength" the bearing back in the gear you will be ok then.
the boss of the idler needs to be bonded use medium strenth into the gearbox casing so it doesent move but...... not in the clutch cover end ... so you can remove it on strip down
hope this makes sense to you
