Home > Help Needed / General Tech Chat > Blow through SC for MPI
MrOz
Member #: 5007
Crazyhill, Livi
I'm back to square one with the MPI - cannot get it to start, so I've bought a wee cheap Skoda as a daily driver.
I'm gonna spend time getting the MPI sorted but was thinking about going for blow through as apposed to suck.
Done a search and found plenty about carb version, but nowt about MPI.
Anyone got any reservations/comments about this?
Was wondering if it would be possible to utilise the standard MPI inlet manifold, obviously I'd need an adaptor plate to either mount the 'charger or pipework.
"se ne estas rompita, ne ripar ĝi - supercharge ĝi."
blister
Member #: 2590
Croydon
i have never seen a blow through mpi ever i would like to,
maybe the reason there is not a blow through mpi is because of the throttle bodie taking the extra pressure?
Look at Rod S' and Paul S' build threads, they are all multipoint injectin and blown through. Just a different blower.
MrOz
Member #: 5007
Crazyhill, Livi
Cheers Andy - I'll have a look and see what the score is.
Blow through supercharger set ups open up a whole other can of worms (see JohnySTi's thread) never mind the increased complexity of the siamese port injection code.
I am not saying it won't work, but the set up you have by the sound of it, is pretty similar to hundreds of other set ups that do work, you will be in deeper that you think if you go the 'blow through' route
Edited by Sprocket on 24th Sep, 2010.
