| Home > Help Needed / General Tech Chat > Need for Crankshaft Harmonic Balance Pullys | |||||||
28 Posts Member #: 1503 Member Long Island, New York, USA |
26th Sep, 2010 at 02:42:23pm
I was told the 1275 engine required the subject crank pulley to minimize vibration to the engine internals.
27th Sep, 2010 at 02:39:31pm
Its possible, but my thought is that the extra load of the supercharger on that end of the crank may well have a damping effect on the harmonic vibration that the balancer pulley is supposed to suppress. |
27th Sep, 2010 at 05:56:01pm
Supercharger belt drives don't do the same as a harmonic damper.
27th Sep, 2010 at 09:28:15pm
I was afraid of that prognosis Sprocket. If you are correct then a whole bunch of us Vmax & Jon Speed guys are going to experience main bearing and or Crankshaft failures. I hadn't thought of this issue until my trigger wheel sheared off the aluminum SC & Alternator pulley and it dawned on me that none of us have the steel damper pulley any more.
27th Sep, 2010 at 09:38:04pm
On the Aus kit I bought, it has the grooves machined into outer part and the belt runs from there.
1425 Posts Member #: 690 Post Whore Norfolk |
27th Sep, 2010 at 09:40:48pm
Theres another topic on here somewhere with my thoughts on crank dampers - I'm not up to speed on these m45 charger conversions - is there any reason the mpi bottom pulley couldn't be used as its poly v type with a damper? If for any reason a damper couldn't be used my thoughts would be to make the crank damper out of steel in en16t- and make it heavy and strong to keep the keyway in one piece and offer a mass for the vibrations to act against opposite the flywheel.
If Carling made Mini engines
29th Sep, 2010 at 01:58:13pm
You were correct! There is another thread but they refered to as a crank damper and I hadn't used that serch term before I started this tread. Much info .......it sure seems like those of us that don't have a crank damper are in for a future failure ^&&
30th Sep, 2010 at 07:14:36pm
On 27th Sep, 2010 minimized said:
If you are correct then a whole bunch of us Vmax & Jon Speed guys are going to experience main bearing and or Crankshaft failures. I was always under the impression that Stuart Gurr, use crank dampers on all of his kits. I know he does on the MPi drive system, but im not overly sure on a standard vee belt drive system. I wouldn't have though a bloke like Stuart would chance it without the damper, considering most of his engines and conversions are in road cars. On 26th Oct, 2004 TurboDave16v said:
30th Sep, 2010 at 11:29:11pm
If I'am not mistaken both Stuart and Jon Speed purchase their all in one solid but machined aluminum crank pulley for the serpantine SC belt and alternator V belt from the same maker. It does have a fair amount of mass, but there is no "Isolation material" between the shaft and the mass... |
30th Sep, 2010 at 11:34:57pm
you need that isolation material really,
1st Oct, 2010 at 07:37:27am
1st Oct, 2010 at 10:41:14am
The theory of having a solid damper and supercharger inertia may be ok - there are enough people out there putting lots of miles on them without breakages - though if we were to do a single piece pulley it would be made from a very good grade of steel not ally and probably a full length keyway in the crank. If Carling made Mini engines
1st Oct, 2010 at 10:47:28am
Thank you John K for those words of support - I thought I had been dismissed out of hand. I know it cant be as effective as a "proper" harmonic balancer, but part of the problem is the effect of a large lump on one end of the crank (the flywheel) allowing the crank to flex torsionally at each firing stroke -more when no 1 fires, obviously.Having a weight or some inertia at the other end may well help to alleviate some of this problem and a steel pulley may be better than an alloy one, both because of its greater weight and durability/reliability.
lol) with a proper fluid damper.
