Home > General Chat > Big Brake converstions
I know a few have you havn't gone down the usuall route when fitting big brakes under 13" wheels. I'm looking for some bigger brakes and looking for ideas on what to go for. Ideally I'd like to use something out a race series as there is a better chance of some good pad compounds being available.
I currenly have the minispares carbon pads, which are very good, just feel with the extra space I have under 13's I could make use of it.
my plan is to go to princess discs and vx220 calipers jim .
hmmm princess discs, I assume they are the same PCD? can you get them vented and groved etc?
not sure .. i think the only ones iv seen were solid ,but BIG !! and i know you like em BIG !
heres a link
that might help
http://www.16vminiclub.com/forums/showthre...hlight=princess
Edited by robert on 27th Sep, 2010.
Asphalt
Member #: 1027
Germini, black forrest
A mate of me runs Wilwood 4 pot calipers with 10" dia. discs *happy* That's some serious stopping power *surprised* I can ask him for details if you like.
[X] nail here for new monitor
AP 2 pot alloy calipers from an Elise can be had cheaply, then use a 2-piece disc off whatever with a seperate bell to get the offset you need.
if you could get more info that would be cool
Have a look at Joes. 10" disk with Wilwood 4 pots.
KAD
https://secure.surfinteractive.co.uk/cgi-bi...iParts:Calipers
Jim if you no the guy os racing ? that built the motor in gold/red mini on your combe wid am sure he runs willwood big disc bell set up.
Obviously kad do a 4pot big disk conversion now or go for there 6 pots on a big disc and bell.
Am sure tarox do somthing aswell.
Rick
Didn't think to check on that Rick, I'll ask him when I see him next
Jim are you finding the 13's a better combo then than the 10's what tyres have you been running on both size's and wot was on on endaf's run.
Sorry for off topic
Rick
we ran the same tyres all weekend 048r's, Grip was much better but handling wasn't as good, but still quite predictable. We found with the extra grib the rear camber brackets where bending, I'm going to have to make some of my own which are simular to the KAD ones without the £100 price tag.
Really looking forward to fitting 13x9 slicks
Anything you can do to improve the handling back to the levels the 10's gave you?
sturgeo
Member #: 1778
Northants
Is there much of a weight difference between new and old rims?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
I also have the minispares carbon pads, fitted into alloy 4 pots, expensive at about £50 but very good stopping power would recommend them!
the 13's are about twice the weight of the old 10's, so that aint going to help, I think we could do with softening the shocks off a little more to make up the for the less flex in the tyre.
If anyone saw me in my first session out they would have seen how twitcy it was and it needed to be softend up from the 10" setup. This was a massive step in the right direction.
I think with more time the 13's could be on the par with 10's
This is the route I am taking on my car
http://cgi.ebay.co.uk/Austin-Maxi-All-Mode...=item4150d9b75c
Those with some peugeot 205 Bendix floating calipers and Drum Brake hubs.
Should have a large brake conversion for under £300 all in, and new
miglia_replica
Member #: 1278
Bedfordshire
Jim if you have his number it may be worth speaking to Ricky who does Paul Clarks Miglia as he is looking into it for mine but the option was going to be wilwood 4pots with VW golf vented discs and they look like they clear my 13" supertrax wheels
I'll give Ricky a ring later, cheers
Jim, note that not all the wilwoods come with dust seals,
seems to be a good range of pad materials, 1144 1155 plus the polymatrix pads are meant to be good too.
In superlites you can just get 10.25" discs (same sizes as the golf discs I think)
Also I went for big pistons in the calipers to give more power (4 x
44mm IIRC)
any photo's of your setup Joe, I did have a search but couldn't find anything? How have you got on with yours?
I thought I had some of the finished setup but apparently not, I'll grab some tomorow, in the meantime...
they are good, the main problem i've had is they are rubbish in cold weather with the 1144's in there, in the summer though you can repeated hit the brakes from over a ton and get tingly balls lol
looks good, did you buy generic disks and make your own bells?
