Home > Help Needed / General Tech Chat > Tapping a hole for a dump valve, boost gauge and mj
Mini_the_minx
Member #: 9077
Cheshire
As above really. I have an Oselli Torquemaster inlet manifold and have (stupidly) just realised I'll need to tap a hole for my dump valve, mj and a boost gauge. Has anyone done this and what connector did you use as I'm slightly concerned about having it all connected as one *oh well*
On 2nd Nov, 2010 wil_h said:
supermotolee
Member #: 2153
kings langley
you can get a plate that goes between the carb and manifold cant u? minispeed do it?
Just get a 1/8 BSP barbed connector like this:
http://cgi.ebay.co.uk/1-8-Bsp-Male-Brass-H...=item45f37987fc
You will need a 8.7mm drill bit and a 1/8 BSP tap. It's really easy to do, just make sure you drill the hole at 90 degrees to a flat spot on the mainfold. Make sure you thoroughly clean any swarf out of the manifold afterwards, you don't want it in your engine...
minx , you dont want to put the dump valve on the inlet manifold after the carb ..youll end up blowing your charge all over the engine bay !
or did you mean your dump valve vacuum signal to go back to the valve mounted on the plendullinium ?
Edited by robert on 30th Sep, 2010.
She also wants to connect the megajolt and boost gauge so it's most likely the signal hose Robert *wink*
Assuming you mean the dump valve sense line (rather than the dump valve itself), drill/tap and use standard barbed fittings as Andy says.
Personally I have two so as to keep the dump valve actuator/sense line seperate from the electronics (MegaSquirt in my case) and I've used 1/8"BSPT/4mm fittings and tube.
(edit, clarify size)
Edited by Rod S on 30th Sep, 2010.
Mr Joshua
Member #: 1954
Luton Bedfordshire
I used an 1/8 BSTP fitting and a little thread lock
Own the day
Anton
Member #: 764
Staffordshire
I used a brake bleed screw with the end chopped off. As it saved me having to find a bsp tap
