| Home > Help Needed / General Tech Chat > Rocker Help. | |||||||
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
1st Oct, 2010 at 09:43:31am
Can you use spacers for the rocker assembly
1st Oct, 2010 at 09:46:21am
Has the head/block been skimmed alot? On 13th Jul, 2012 Ben H said:
1st Oct, 2010 at 09:52:44am
On 1st Oct, 2010 Vegard said:
Has the head/block been skimmed alot? How will this make a differance? Isn't this problem caused by long valve stems? or massively recessed valves? Mine have evidence that they do this. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
78 Posts Member #: 9073 Advanced Member Edinburgh |
1st Oct, 2010 at 10:34:10am
Has the head/block been skimmed alot? How will this make a differance? If a lot of material's been taken off the head the pushrods will protrude more out the top upsetting the geometry. Nial. |
1st Oct, 2010 at 10:45:21am
Has the head/block been skimmed alot? How will this make a differance? If a lot of material's been taken off the head the pushrods will protrude more out the top upsetting the geometry. Nial. Yes, but it won't affect how close to the valve cap the gets to the body of the rocker. This is fixed even if you skim the head back to the valve face, surely. Or am I being thick? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
1st Oct, 2010 at 11:01:50am
Or am I being thick? No, I didn't read the original post properly :$ Nial. |
1st Oct, 2010 at 11:08:56am
I didn't read the post properly either, but normally when spacers are needed, this is because the push rods are too long, or if valve stems protrude because of sinking in valves etc.
1st Oct, 2010 at 02:22:31pm
ok doubt it has been skimmed.
Edited by NickG on 1st Oct, 2010. |
1st Oct, 2010 at 04:18:44pm
On 1st Oct, 2010 NickG said:
ok doubt it has been skimmed. it is a lovely turbo phill head. so what should i do, they look close that they could touch or are touching. i was doing it with my mechanic he said it is so close it's a 50-50 it could drop a valve??? my normal bog standard rocker assembly i think fits fine. can i use some sort of spacers or shims or anything??? what about this---> http://www.minisport.com.au/prod1916.htm thanks for help lads :) No, that won't help one blind bit. What you need is rocker pedestal shims. On 13th Jul, 2012 Ben H said:
1st Oct, 2010 at 07:25:22pm
Vegard you are a legend.... You think should fix it?
1st Oct, 2010 at 07:46:59pm
All good mate found them! |
1st Oct, 2010 at 08:01:58pm
I had to use rocker pedestal shims when I was running 1.5 rockers. I run a supercharger and I don't care the TB is on the wrong side.
1st Oct, 2010 at 08:38:54pm
this ones are 1.3 titan's going to hunt around. |
1st Oct, 2010 at 08:40:28pm
I ran 3mm shims I run a supercharger and I don't care the TB is on the wrong side.
4th Oct, 2010 at 11:58:43am
2mm shims sorted it :) looks like the last owner run the rockers with no shims & it's been hitting. hehe |
4th Oct, 2010 at 08:36:38pm
The head only had a very light skim, iirc about 8thou. So it's a bit strange ? |
