| Home > Help Needed / General Tech Chat > Float level in HUF38 / HIF44 | |||||||
78 Posts Member #: 9073 Advanced Member Edinburgh |
1st Oct, 2010 at 10:43:00am
I've recently installed a wideband lambda sensor to try and get
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
2nd Oct, 2010 at 12:21:12am
Nial.
2nd Oct, 2010 at 11:31:50am
On 2nd Oct, 2010 turbominivanman said:
Nial. What cc ? What cam ? What rockers ? NA or turbo ? Std '93 1275 NA, but I don't want to know what it should be, just what the normal range could be, I'm fairly sure mine's too low and the idle AFR is _very_ variable. However, for a 1275, I know that for an HIF44, to get a steady AFR within the range 14:1 - 15:1, then the jet height can vary between cars as to be level with the bridge to about 3 mm down the jet holder (which is about where mine is on my turbo van on an HIF44).
Great, thanks for that, would you expect to get a 'solid' idle AFR which the engine will return to (+/- a small amount) every time the engine returns to idle? It was early last week when I measured it but I think the jet's sitting a good bit more than 3mm down (4.5?). I think I'll look at the float level again. Thanks, Nial. |
2nd Oct, 2010 at 11:25:20pm
Sounds too rich if the jet is that low.
