Home > Help Needed / General Tech Chat > Brake pipe diameter?
m4dn35s
Member #: 243
Portsmouth
Hi all, Could anyone tell me what the brake pipe diameter is on a mini? Is it 1/4?
Cheers matt
WooHoo Passed it's MOT!!!! One of the cars in The Portsmouth Mini Turbo Massive!!
Dangerous
Member #: 417
pretty sure its 3/16 as I just looked at me flaring tool and it goes straight through the 1/4 hole but fits nice and tight in the 3/16 hole
clubman_dan
Member #: 142
Winchester
3/16 almost certain
turboestate
Member #: 362
durham area
All mini brake and clutch pipes are 3/16. *happy*
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
m4dn35s
Member #: 243
Portsmouth
ahhh cool cheers lads. *happy*
Rammie2000
Member #: 10190
belgium
old tread i know but was looking for brake size. found the tube size but what screw niples should i order ( i used all the one's i had on the previous mini and never looked at what they wore.)
edit: should i use classic copper pipe or the modern cunifer (copper nickel mix) for the tube's?
Edited by Rammie2000 on 8th Dec, 2014.
SadamPl
Member #: 10924
Wroclaw/Poland
You mean the brake unions like this?
http://minispares.com/product/Classic/Brak...k%20to%20search
Usually they are 3/8 UNF, brake limiter fitted from the 1980 on uses M10x1. In some older master cylinders (yellow band) they used something bigger for one of the sections, but I can't tell now whtehr it was metric or not.
Edited by SadamPl on 8th Dec, 2014.
Made in Poland build thread:
http://www.turbominis.co.uk/forums/index.p...tid=570363&fr=0
slater
Member #: 1291
Suffolk / Birmingham
Depends what exact brake components your using. Minis used a mix of 3/8unf and M10x1 fittings over their life span so either check what you need or get a box of both.
Be careful too! its easy to screw the wrong threads together.
I would always prefer kunifer, but copper is easier bent and worked with, especially if your flaring tool is less than great
Rammie2000
Member #: 10190
belgium
Okey. I know what ill use for clutch but still need to deside what brake pump (had to remove the servo so need to go rugular...)
The tool isn't that bad i have to press them by hand but it works very well.
