Home > General Chat > ebay ad
Dolly
Member #: 9061
Louth
i have seen this and was interested in buying it but didnt want to pay over the odds what do you lot think its worth? cheers in advance for any help
Dolly
Member #: 9061
Louth
oopsie forgot the link silly me http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...e=STRK:MEWAX:IT
Amp
Member #: 7856
It's worth what you want to pay, complete ones go around £500 usually, this one is in bits though, so if your building it yourself be prepared that lots of parts will most likely need replacing. If your on a budget then maybe this is the best option, otherwise you'd be better to get a stock 1275 engine and uprate the pistons and head, and use that!
Mini_the_minx
Member #: 9077
Cheshire
As said, it's entirely down to what you are willing to pay for it. I personally wouldn't buy it since it's been sat around for 5 years but that is just me. If you've got the money to replace bits that will inevitably need replacing go for it but I'd rather see an engine before I consider buying it.
On 2nd Nov, 2010 wil_h said:
i dont see why being sat is an issue, the newest metro turbo engines are all over 20 years old now and anything you buy needs stripping down and rebuilding.
i would look at it all first the hard bits to find are the return drain, carb, turbo, and manifolds if these are in good condition then its worth buying, if there shot then its not as you can buy a 1275 fairly cheaply and in affect thats all you are getting
Mini_the_minx
Member #: 9077
Cheshire
Being sat in a cold damp garage is never going to do it any good compared to keeping it inside the house (like mine) and the amount you'd pay to get the bores honed because they've rusted you might aswell buy another slightly more expensive engine but in better nick.
thats crap as i said metro tubo engines are at least 20 years old and anything you buy will need rebuilding so a hone is irrelavent
personally i would not pay the premium of a turbo engine, i would get a good 1275 rebuild it as a turbo and buy the turbo manifolds and carb seperate, you know what your getting and how good it is then
Edited by wolfie on 2nd Oct, 2010.
I'm with wolfie... my car sat for 14 years when I first got it I ran it as my first car for 2 years. It then sat for another 11 years until I started to use it again, in 2007 I put the SC kit on it and its been running over x2 the power since then.
The bottom end was built in 1969.
Mini_the_minx
Member #: 9077
Cheshire
Not really when you consider someone else might be selling a turbo engine that has been run recently and rebuilt before. But each to their own, like I have already said.
Dolly
Member #: 9061
Louth
cheers for the replies guys and gal i think im going to give it a miss thanks amp for the pm
