| Home > Help Needed / General Tech Chat > Running fuel lines, any tips | |||||||
23 Posts Member #: 9069 Member Dumbarton |
3rd Oct, 2010 at 09:13:00pm
Just ripped out all the old steel fuel lines and am about to replace with 8mm copper microbore.
Edited by tonton on 3rd Oct, 2010. |
3rd Oct, 2010 at 09:34:43pm
It's possible so long as you use a good quality microbore tube bender and run it with the subframe off. I've done mine 8mm (flow) and 10mm (return) copper microbore but without the proper bender it just kinks on the tight curves. Also make sure you use brand new microbore - copper work hardens very easily so never re-use old stuff. Schrödinger's cat - so which one am I ??? |
4th Oct, 2010 at 09:41:58am
If you know how to solder copper pipe ie for house fittings you can do the same for your fuel lines. Save bending, just cut to length and use ninety degree fittings job done. send GinoR32 a PM as I saw him do this to his car. Own the day
4th Oct, 2010 at 09:54:47am
I cut mine at the end of the floor and ran rubber hoses from there.
4th Oct, 2010 at 08:35:03pm
thanks,for the advice think I will cut it at the subframe and join it with flexible pipes as you say. Just dont fancy dropping the subframe. Plus I have 10m of the stuff so can have plenty of practice! |
