Home > Wanted > Pressed steel Rockers
Now that I have been thinking, and after Retroracer1380 has kindly sorted me out with some con rods, I really need some pressed steel rockers. The 948 engine never came with sintered rockers, and it would ba sacrilege to not fit pressed steel items.
Can anyone again help, please. All we have is a crank, a block and a head, and we need to put an engine together :/
Thanks in advance
Edited by Sprocket on 4th Oct, 2010.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
I have a few sets I believe
Andre, How much to post a set to the UK?
I need your address anyway to send this tensioner *wink*
miniminor63
Member #: 672
Oslo, Norway
just postage cost. I will find out and let you know.
retroracer1380
Member #: 1972
Worcester
I have some of them as well colin! Should have said. I take it you want the round pad small bore ones? What else do you need as ive just stripped two 850 engines, one very early prob 1959-60, il hangon posting the rods
Edited by retroracer1380 on 5th Oct, 2010.
You are my new best friend *happy*
Yes, deffo small bore ones. I'll have them please :)
I'll have to sort you out with something whatever that might be.
No idea what this chap has done with the original rods or rockers, but everything else is there.
Andre, Thanks for the offer.
Top stuff chaps
Oh and I have said it before, and I'll say it again. TM is GREAT!!*happy*
retroracer1380
Member #: 1972
Worcester
Ok colin il stick them in with the rods
miniminor63
Member #: 672
Oslo, Norway
Are you building a 948?for what?
Its a standard build for a Midget.
Im not overly keen on the +0.030" 5 ring pistons with a huge thermal slot , so the pinch bolt rods won't be an issue.
The cam runs in the block without number 2 and 3 babbitt bearings too
Edited by Sprocket on 5th Oct, 2010.
