Home > Help Needed / General Tech Chat > Centre main Strap
NickG
Member #: 7912
Australia oi oi oi!
I have read about it.
my engine is out just putting my quaife in & new gears.
will i need a main strap?
where can i get one? im not after the 4bolt thing though that med sell.
do i really need it? i can't see my car getting over 90atw's with the supercharger.
maybe this
http://www.minispares.com/Product.aspx?ty=...id=37539&title=
is it a big job? my mechanic is doing my box should i go drop it to a machine shop to do the strap?
Edited by NickG on 6th Oct, 2010.
With an SC and a maximum rpm no higher than 6 to 6.5k I wouldn't bother.
Don't bother. It's said that it helps on high revving engines (not yours) but this is never really proved, and I know several people that has stopped using them. Including som very professional race engine buiders.
The strap causes more problems than it does good. The main problem is getting both the strap and cap flat when its torqued down. if you fit a strap, it should be line bored, but most dont and put up with the slight cap distortion. If the crank does not nip up, then fine, But I have seen too many where the cap nips up on the crank, and all it needs in most instances is to invert the strap and its fine, indicating something is not quite right with it.
NickG
Member #: 7912
Australia oi oi oi!
ahh excellent..
thanks lads.. thought I would check..
you never know.
knowing now what i didnt know then, i wouldnt bother either, ( mainly how much hassle i had)
Star Mag
Member #: 375
Leicestershire
What hassle did you have?
I've not got one, not bust it yet at over 7500rpm.
I've had one made for my block. Fast Carl did it. Both mating faces machined in his mill. His advice was to use grinding paste between the two to ensure a proper mated surface
3 different sets before i found one im happy with
1 not flat, 1 not thick enough 2 sets of bolts, and then Carl to the rescue :)
clubbie70
Member #: 8935
netherlands
""His advice was to use grinding paste between the two to ensure a proper mated surface""
please explain..
Nick G - so far I've not needed anything, highest rev limit I have had has been 6300. and my bottom end was built in 1969 I would guess the engine has done about 9k with the SC
please explain..
it comes flat straight off the machine, close enough but if you lap them together ( like a valve and seat) you get a closer... hmm i cant think of the word
Tolerance Brett?
It ensures both surfaces are as closely matched as possible.
tadge44
Member #: 2500
Buckinghamshire
I think more people fit straps than need to, possibly for bragging rights. Done properly is some insurance on a competition engine. as an earlier contributor has said, 7000+rpm occasionally does not need this -I,ve used 7300 so far without a problem on a standard Midget crank ,rods , caps and bolts.
I've quit using them whatsoever. What good does it do?
