Home > Help Needed / General Tech Chat > Help with my ring... :)
madcatminis
Member #: 5327
Dudley, West mids
Ello peeps. I've searched and searched but can't find any info on the problem I have. I acquired so 'turbo' pistons ages ago and have a query about rings. Most of the standard pistons I see have 3 grooves for rings however mine have 4. Whats the deal with these then lads???
They are not Metro Turbo Pistons. They look like Early A+ 1275 +0.030" pistons to me
madcatminis
Member #: 5327
Dudley, West mids
Your bang on right sprocket. I've just dug out a standard A+ block out and tried to drop them in and guess what, they don't fit the bore. Bugger!!!!
madcatminis
Member #: 5327
Dudley, West mids
Does anyone know what pistons they are or can put me on with a link with some info. *happy*
retroracer1380
Member #: 1972
Worcester
Ive stripped a couple of pre a plus blocks with these in, at plus 30, bit old hat now wouldnt bother with them tbh, and +30 is an odd ball bore now adays
+015 and +030 were common rebore sizes in the good old days.
I've got a standard engine, pre A plus block and 4 ringed pistons stamped +030 as well (but no part number, just the oversize stamped).
Keep the pistons. It's easy to fit .040 rings to them if you've got the correct tool to grind them down.
NickG
Member #: 7912
Australia oi oi oi!
you need some cream for that.. lol. *tongue*
Edited by NickG on 8th Oct, 2010.
I wondered who would be the first! *hehe!*
NickG
Member #: 7912
Australia oi oi oi!
I'm very surprised I am with you lot.. lol.
ill run away madcatminis lol.
i was abit unsure if to click or not i was unsure what possible pics there would be *happy*
madcatminis
Member #: 5327
Dudley, West mids
I've just used a pipette on the piston dish and I'm getting 21ml. I've googled how to convert this to cc and it says it's the same. If so then this is a massive bowl, or am I just being a retard???
Any ideas????
h4887
Member #: 2404
Braintree, Essex
A millilitre is the same as a cubic centimetre *Nerd*
Geoff
yep a cc is the same as a ml, also a ml of water weighs 1 gram iirc,
sounds like your measuring has gone awol, those pistons should be around 9-10cc
madcatminis
Member #: 5327
Dudley, West mids
Well I thought I was going mad but I'm definatly not. Measured them again and getting 20+ ml in there. I've used a medicine spoon this time and poured in x4 5ml and it's just shy of the sides.
Here's a couple of photo's to show how deep the dish is.
