| Home > Help Needed / General Tech Chat > Hot air release from engine? What you got? | |||||||
![]() 94 Posts Member #: 7701 Advanced Member Amsterdam Holland |
8th Oct, 2010 at 02:50:45pm
I searched here for the options/thoughts or pic's off bonnets with ais scoops [or is it scopes?] or releated..Couldn't find it,only some bonnets wich where "mounted the wrong way round"on the mountigpoints..with a open side at the scuttle..
It's a little car .... eating big money |
8th Oct, 2010 at 03:46:22pm
the pics, 2 and 3 show a good placement, allowing hot air to rise out the engine bay when stood still, but when moving the aerodynamics of the mini will force air down the vent ( scoop Edited by Brett on 8th Oct, 2010. Yes i moved to the darkside |
8th Oct, 2010 at 04:44:59pm
Aerodynamics is even worse..it's a clubman 8-)
![]() 539 Posts Member #: 6807 Post Whore York |
8th Oct, 2010 at 05:06:32pm
As brett said, the scuttle is a high pressure area while the car is moving, hence the air flow will go in the opposite direction than you intend. |
8th Oct, 2010 at 05:23:02pm
On 8th Oct, 2010 clubbie nl said:
Aerodynamics is even worse..it's a clubman 8-) The idea was to create a sort of vacuum behind the open side while driving that sucks out the hot air.. in theory it would work like that, but the whole front of the mini act's like a big fat scoop so mounting the bonnet scoop backwards, gives better flow into the engine bay there is a thread on here somewhere buy ( i think turbo dave) demonstrating this with some string, raising the back of the bonnet 'to let hot air out' ( as they say) actually cold air gets pushed in down the back ( good for a carb imo) edit: wrong quote Edited by Brett on 8th Oct, 2010. Yes i moved to the darkside |
8th Oct, 2010 at 05:57:48pm
@brett, thanks for the pdf file..made it all clear and visible for me.
8th Oct, 2010 at 07:36:47pm
sorry, non turbo with a carburettor and k&n filter, the air intake is at the back of the engine bay at the top, the raised bonnet or backwards facing scoop is a good cold air intake Edited by Brett on 8th Oct, 2010. Yes i moved to the darkside |
