Home > Show Us Yours! > modified mirage...
supermotolee
Member #: 2153
kings langley
Whats that for then? External wastegate?
You carnt just post a pic like that with no explination .*frown*
Rick
looks like an external w/g flange to me,
any reason other than a screemer pipe?
t@z
Member #: 452
Chester, UK
lee your gay!!! u should have waited till i had done mine!
www.twitter.com/lilpinkiy
quinton
Member #: 1911
I was gunna say the same as you brett. For a screamer pipe I'm right in saying that it doesn't get plumbed back into the exhaust, as in it just stays on it's own?
Must admit I know someone with this does as first time I heard him floor it, it scared the hell out of me.
Can an internal WG turbo be converted to external WG?
Sorry for high-jacking.
yeah basically when it comes on boost it gets loud as fook as the wastegate gasses are dumped straight to air ( like the DON, look at the turbo downpipe there is an external dump tube( but it still has an internal wastegate)
the easy option is to leave the actuator on the standard internal wastegate with alot of pre-load and dont plumb it in fitting an external, or you could weld the wastegate closed on the turbo, and obviously some dont have internal wastegates atall
quinton
Member #: 1911
so this kinda setup would work? would you actually free up the turbine or would the real benefit be noticed through an external WG
http://www.300zx-club.com/forum/showthread...6-Screamer-pipe
supermotolee
Member #: 2153
kings langley
supermotolee
Member #: 2153
kings langley
yes its an external wastegate
WOW!!
The 70's!! lol
Is that a T2? If so won't it be 'screaming' quite a bit?
supermotolee
Member #: 2153
kings langley
its my iphone camera app thing
yeah t2 for now
Will that fit under the bonnet???
supermotolee
Member #: 2153
kings langley
oh shit never thought to check... *wink*
yeah it fits... its at a slight angle pointed towards the master cylinders should sit about level with the top or carb/pendulem
Edited by supermotolee on 13th Oct, 2010.
PHEW!!!
t@z
Member #: 452
Chester, UK
good work now you can help me with mine so we can asbo our cars!
