| Home > Help Needed / General Tech Chat > Sorry another turbo querie, ko3/k04 | |||||||
9th Oct, 2010 at 01:11:35pm
Some have mentioned the ko3 orthey do a ko3 s that our kid has on his and produces the goods?
10th Oct, 2010 at 12:41:00am
k03s/k03 is used on 1.8t 20v vag, they did two different turbos , but this is pre 2000 concept they do have a different bolt arrangement with three holes.
Edited by fab on 10th Oct, 2010. |
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
10th Oct, 2010 at 09:58:59am
the ko3 fitted to vag 1.8T's up to mid 2000 is good for around 190bhp at 16psi as an absolute max, on the 20vt it won't boost higher than that, and even then, it'll only hold 7-8psi at 6000rpm. it's proper heat pump though, with inlets reaching almost 70 degrees when using the standard SMIC
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
