Home > Help Needed / General Tech Chat > small miglia alternators not the jap ones
ok then Where can i get an alternarort like this.
http://www.flickr.com/photos/dazecoop/6122...57594452233103/
http://www.flickr.com/photos/dazecoop/6129...57594452233103/
Any info that would help would be great. I have been looking for them for a bit now.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
they are used on large lawnmovers. they charge between 10 and 18 amp and need a regulator on the side.
They look interesting. Let us know if you find some...
Yes there off a kabota (not sure if thats how its spelt) obviously just enough chargre for the race and small and light.
Oh ye they are from a lawnmower
Rick
Prawn
Member #: 5232
basingstoke
I asked this when I was at Combe last, apparently they're from a Kubota digger!
Those engine bays in the pics are both se7ens by the way! Single barrel being used on the webber and dizzy ignition
ta da
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=290484658242
Good find mate.
chinlesswonder
Member #: 1192
In the garage......again!!
he says he's upgraded to one with a built in regulator, that could be interesting.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
There are shed loads on ebay USA. search for kabota alternator
Timinichelsea
Member #: 479
They aren't that good on a road car, they need to be run flat out to charge, which wont work well on the road, but they are good on the track.
blister
Member #: 2590
Croydon
cant you just down size the pulley that it will use? making it seem like it is running flat out?
Prawn
Member #: 5232
basingstoke
won't that then overspeed it at full revs?
blister
Member #: 2590
Croydon
oh thats right
"good thinking bat man" *happy*
what about slightly larger then smaller then
If you use the type with a regulator you cant over rev it as it cuts out at a certain amount of power output as with the Denso type
Timinichelsea
Member #: 479
Oh that sounds better. I didn't know you could get them.
I'll have to look into those as well then.
Ben H
Member #: 184
Melton Mowbray, Pie Country
I don't think the over rev problem is a voltage issue, like you say the regulator will sort that. But the rotor might disintegrate at high rpm.
http://www.twin-turbo.co.uk
Good point Ben, never considered that. Spose its a suck it and see on that
