| Home > Help Needed / General Tech Chat > Megajolt + JAW or Megasquirt 3? | |||||||
![]() 338 Posts Member #: 1911 Senior Member Swindon |
10th Oct, 2010 at 09:44:10pm
My question is can I use megasquirt for ignition mapping and AFR monitoring and logging without fuel injection or not? Cause original idea was megajolt then I was informed about JAW by Sam and I'm stuck in what to do. It's about £120 for megajolt now and just over £200 for JAW (just another wideband).
10th Oct, 2010 at 09:48:07pm
I'd say the cheapest way is MJLJ v4 and an AEM Wideband. If something is worth doing, it's worth doing half of. |
10th Oct, 2010 at 09:50:32pm
AEM wideband's aren't cheap either! still well over £100 |
10th Oct, 2010 at 09:59:52pm
whats JAW?
![]() 362 Posts Member #: 114 Senior Member Porto/Portugal |
10th Oct, 2010 at 10:04:41pm
On 10th Oct, 2010 quinton said:
AEM wideband's aren't cheap either! still well over £100 http://cgi.ebay.co.uk/AEM-Bosch-Wideband-U...#ht_2968wt_1284 Pedro Silva
10th Oct, 2010 at 10:06:14pm
thats just the sensor, you need the gauge(controller) too,
10th Oct, 2010 at 10:06:49pm
yea sim and add the price of a gauge to go with it.
10th Oct, 2010 at 10:21:33pm
Can we connect the wideband sensor to the aux input from megajolt!? Pedro Silva
10th Oct, 2010 at 10:31:56pm
you can connect the output of the the wideband controller to the aux input of the jolt On 28th Aug, 2011 Kean said:
10th Oct, 2010 at 10:45:01pm
You can use MS2 or MS3 for ignition, AFR monitoring and logging without using fuel injection. However, you'll still need the WBO2 controller.
10th Oct, 2010 at 10:45:03pm
the wideband can potential be the best buy you will make Yes i moved to the darkside |
10th Oct, 2010 at 11:30:23pm
Ah right. Now knowing this MS 2 looks like the better way to go with future capability. |
11th Oct, 2010 at 09:19:26am
If you are/were thinking about the 14point7.com stuff you must be happy with DIY/soldering etc. so I would suggest you consider an MS2 in kit form.
11th Oct, 2010 at 10:17:06am
Cheers rod. I'll get the real kit and like u say get build the parts on that I need. That's a good part to know with direct to the coil. Yea putting it together ain't going to be hard, it's the understanding of it. |
11th Oct, 2010 at 10:37:14am
If you buy a full kit, make sure you buy a second ignitor chip, VB921 (or probably now a ISL9V5036P3) as the normal kit only comes with one to drive a standard single coil/dizzy setup. You need a "pair" to drive a coilpack.
11th Oct, 2010 at 10:03:58pm
12th Oct, 2010 at 09:31:46am
From your list of can/can't do, the only one I'm not clear about is boost control. MS2 (using the Extra Code)certainly does boost control using a two dimensional map of throttle position and RPM but what I think you are saying is it doesn't give you two or more modes of operation ie, you only want the highboost/output some of the time. If so, I agree, but..... as the boost control is performed by simply using an electronicaly controlled bleed valve (very accurately as it's PWM driven from the MS2 and you can even have closed loop control), with a bit of ingenuity you could probably just add an external switch to take the drive signal off the solenoid valve and to a dummy load resistor in which case boost would drop back to simple actuator control. (you would probably have to forgoe the closed loop control option in that case or the ECU would be chasing an impossible target).
12th Oct, 2010 at 09:51:52am
Cheers for that rod, much appreciated taking time to read that. |
12th Oct, 2010 at 10:29:22am
I think that you would be better selling that head and starting again. iirc with the 36/30 valve combo you end up with not much materialbetween the valves which is likely to crack with thet extra heat of the turbo.
12th Oct, 2010 at 10:14:46pm
Checked with phil about my head spec and he says it's fine. |
it is possibly the most usefull tool for tuning and monitoring the engines workings
