Home > Help Needed / General Tech Chat > Should I use Megajolt MAP or TPS?
m_brady15
Member #: 8011
Hello everyone,
I am going to get my megajolt system soon but i'm unsure whether to use MAP or TPS for my setup.
I have a 1293 metro turbo with a phase 2 avon bar cam, standard turbo carb and will be running around 150bhp.
Any advice would be great as im quite new to the MJ system.
Many thanks
Miles
Edited by m_brady15 on 11th Oct, 2010.
shane
Member #: 1246
Lowestoft, Suffolk.
If using std hif44 carb I think most on here use MAP.
Shane
sturgeo
Member #: 1778
Northants
Map definitely on a turbo engine.
MAP
m_brady15
Member #: 8011
Ok thanks everybody :)
Also is it possible to convert a TPS to a MAP and if so how do you do it?
Many thanks
Miles
Yes you can convert TPS to MAP. Rob H on here did mine.
my omex takes signals from both, it surprises me that megajolt dont
philc
Member #: 1346
bromsgrove
Many thanks
Miles
you have to disconnect the MAP function/components on the mother board and put the components for TPS, but you will need MAP so would not bother
Edited by philc on 12th Oct, 2010.
