| Home > Technical Chat > Baulk Rings | ||||||
458 Posts Member #: 1840 Senior Member Kings Lynn, Norfolk |
12th Oct, 2010 at 09:29:05pm
Any body got a good source for genuine or good quality repro ones? As minispares are out of stock until the new year, and its hard to know what your getting from the other suppliers.
12th Oct, 2010 at 10:23:33pm
On 12th Oct, 2010 advantage998 said:
Any body got a good source for genuine or good quality repro ones? As minispares are out of stock until the new year, and its hard to know what your getting from the other suppliers. For instance minisport list genuine rings for £6.39 which can't be right as there usually £20+ http://www.minisport.com/mini-spare-parts/info_22G2033.html Minisport mostly supply inferior products and pass it off as genuine with a genuine part number. What you see in the picture, is usaly not what you get. Also, if its competition specification and suitable for road, how does that make it genuine? when genuine ones would be suitable for the road, and perhaps ok for competition? Hope that helps you make your mind up what to buy Edited by Sprocket on 12th Oct, 2010. On 26th Oct, 2004 TurboDave16v said:
13th Oct, 2010 at 06:03:35am
Aye that whats i thought, thanks for confirming, will have a ring round a few places but if not, looks like i'm waiting till next year then. |
13th Oct, 2010 at 10:43:26am
Are your current ones definately knackered? Aslong as they push onto the cone and dont bottom out or turn they will be fine to use again
I seriously doubt it! |
13th Oct, 2010 at 10:52:11am
I agree with paul. I re-used my original bulk rings as they were in good condition and better then the "competion" ones I'd bought from a reputable suppier. On 7th Oct, 2010 5haneJ said:
13th Oct, 2010 at 11:09:00am
I agree too. Old rings are preferred as long as there is ATLEAST 0.8mm clearence to the gear itself. On 13th Jul, 2012 Ben H said:
13th Oct, 2010 at 10:12:31pm
Two of them measure less than 0.8mm, they dont bottom out but i was overly confident in using them.
14th Oct, 2010 at 05:27:58am
http://www.gerardsgarage.com/Garage/Tech/b...aulkringsWS.htm |
14th Oct, 2010 at 05:54:31am
Thats an interesting read, i'll have to see if any suppliers have the 'flat toothed' type. |
14th Oct, 2010 at 07:26:38am
On 13th Oct, 2010 advantage998 said:
Two of them measure less than 0.8mm, they dont bottom out but i was overly confident in using them. Will see if i can find some old boxes to strip. If it's only for a short while, then OK, but they WILL wear out. I wouldn't. Try them on a different cone. On 13th Jul, 2012 Ben H said:
