Home > Wanted > stuff
blister
Member #: 2590
Croydon
i got the coil pack and leads i just need everything else for megajolt
turbominivanman
Member #: 1504
Westbury, Wiltshire
Hi mate.
I have a Ford VR transducer trigger wheel pickup sensor, 2 coolant temp sensors and a Rover Green air inlet temp sensor if you need them.
PM me if you'd like them.
Richard.
blister
Member #: 2590
Croydon
does the sensor come with the wire?
and the temp sensors can they be used with megajolt?
turbominivanman
Member #: 1504
Westbury, Wiltshire
The Ford VR sensor is in the box, it would require the 2 pin Junior connector and some lengths of wire but the connector itself is very easy to get hold of.
In fact I think I have a new one spare, with the proper pins that you can solder onto your own wire.
I have the thermal resistance curves for the temp sensors so if its anything like Megasquirt which I use, then it would be a case of you using three points on each curve to input into the software.
But best bet would be to do a search or ask a MJ question in a 'Help Needed' post about how you go about programming in temp sensor info into MJ. I dont see a problem, most will have to do this.
Richard.
Billys Bits
Member #: 8949
surrey
does this set up with the curve work with megajolt though?
for example the inputs?
Edited by Billys Bits on 15th Oct, 2010.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Dont know mate, that's what the search button is for tbh.
I'm a Megasquirt user but Megajolt also uses these CLT and AIT sensors so someone knows about how to get the resistance/temp profiles into the software.
Blister - here's a pic of the sensors I have. The crank sensor has a used junior timer connector on it at the mo but I also have a new one'.
Richard.
blister
Member #: 2590
Croydon
hello mate sorry about delay been trying to learn abit more,
cant seem to find anything consirning the rest of the set up but i am interested in the the trigger wheel sensor, how much do you want for it and i wish i saw your boost gauge advert sooner as i had just paid for one that is from hong kong couple minutes before logging into here..........next thing i am after is an internal linkage dont suppose you have one do ya?
turbominivanman
Member #: 1504
Westbury, Wiltshire
PM sent to you Blister about the VR sensor.
Cheers.
Richard.
