Home > General Chat > dyno set up cost?
kstead
Member #: 1126
peterborough
Anyone got any idea what it would cost???
For me to drop of my engine fully built and let em go on it??? just a bit worried about a dead start with the mj, dubious pistons, rebuilt carb, potentionaly gt17 etc.
Your thoughts please gentlemen.
Well the mj comes with a base map with it anyway, but are you meaning engine dyno, or rolling road ?
Rick
kstead
Member #: 1126
peterborough
Yeah was thinking engine dyno so it's all ready to drop in. Like in bill solice vid. May give those guys a shout.
kstead
Member #: 1126
peterborough
Would it normally fire straight of the map it comes with???? Then fine tune
jamesfawcett
Member #: 218
Bingley, West Yorkshire
mine wouldnt run right on the megajolt basemap, but Steve Levits i believe drove his for quite a while without realising it wasnt pluged in right. i think the basemap is about 10degrees fixed or something like that?
i have loads of megajolt maps here you can download to work from (see my signature). Also a wideband lambda really is a must.
hope this helps
Coupe
Member #: 2178
Leyland, Lancs
Its not the Megajolt thats fixed 10 degrees, its EDIS on its own. Even without the Megajolt functioning, the EDIS will provide 10 degrees advance as long as it has power and a feed from the crank trigger so should be enough to start the car.
tomf
Member #: 1746
Kent
Hi jamesfawcett, i dont know if its just me but it wont let me log in, so i tried to registure again, but it wouldnt accept and security answeres i put in so i gave up after trying about 10 times.
Scruffy
Member #: 328
Seaford Rise, South Australia
A proper mapping session will cost upwards of £350 - you can get it done cheaper but you get what you pay for!
On 5th Sep, 2011 Vegard said:
jamesfawcett
Member #: 218
hey tom, is it the captcha?
ive just changed it to a calculator style one,
the only reason i need it on is because i got so much spam and fake bots signing up:(
or if theres one in particular you want let me know ill email you it :)
jamesfawcett
Member #: 218
hey it seems to be working now 3 people have signed up today let me know if you have any more problems or want them emailing
thanks
james
