Home > Help Needed / General Tech Chat > MEga jolt spark plugs + resistance question.
NickG
Member #: 7912
Australia oi oi oi!
The Standard ford plugs that come with the Edis are they resistor leads?
or should i get resistor plugs for my mega jolt? what type of plugs should i use.
I had to re mount my sensor on my bracket how close does it have to be.
I marked everything, I have tried to make sure it's as close as can be or the same to other sensor mounting.
lastly.
when I test my MJ unit can i still leave my dizzy in place? to make sure the MJ is working then pull the dizzy out???
Thanks. *happy*
Edited by NickG on 14th Oct, 2010.
KLAS
Member #: 2380
Hamburg, Germany
i'm using custom made MSD leads and non-resistor plugs. no problems at all. don't know about the factory ones, but i think they are resistor ones.
i use 0.8 to 1.0 mm between triggerwheel and sensor
i kept the dizzy for 3 month, just to make sure. but it was never needed.
Edited by KLAS on 14th Oct, 2010.
NickG
Member #: 7912
Australia oi oi oi!
thanks klas so keeping the dizzy in wont effect it at all?
ill have to find out about the factory leads.
i would like nicer type leads though.
There is a general view that electronic driven ignition (ie, MegaJolt/EDIS/coilpack) needs resistive plugs or resistive leads simply to prevent high frequency noise (that would be present without resistive plugs or leads) from affecting the electronics. I'm doing all my testing with resistive leads and standard plugs, no problems so far.
My sensor gap (MegaSquirt but identical VR sensor) is also 0.8mm.
Leave the dizzy in until you're happy with the MJ (so you can quickly swap over if the MJ setup fails) but, when you do finally take it out, remember to withdraw and remove the drive shaft too.
Johnny
Member #: 6926
Accrington
how do you know if they are resisted? if i have BCR8ES plugs does the R stand for resistor/resisted?
yes
Johnny
Member #: 6926
Accrington
in that case, i am using them plugs with my megajolt setup and its been running fine so far and they are gapped at 0.9mm
