| Home > Help Needed / General Tech Chat > Engine spec and turbo choice | |||||||
272 Posts Member #: 9125 Senior Member Sheffield, South Yorkshire |
14th Oct, 2010 at 05:19:52pm
Hi guys im new to the forum aswell as the forced induction side of things. i have an engine spec in mind but not sure what is needed for the tubo conversion and the turbo to use, so was wondering if you guys could look over what engine spec i am planning on and if it is any good along with the turbo choice and parts needed.
The turbo build has finally started |
14th Oct, 2010 at 05:25:56pm
You should start with a horsepower target. This may be useful
14th Oct, 2010 at 05:27:30pm
Is the SW10 cam suited to turbo use?
14th Oct, 2010 at 05:31:51pm
im not sure about the cam its just that there have been no reports of any1 using it befor and i would like to try it out. apparently it is like the MD286 just a bit better on emissions. as for power i was thinking somthing in the region of 130-160bhp.
14th Oct, 2010 at 05:33:03pm
what about the parts needed to make it a turbo and what turbo to use? T2/T3? The turbo build has finally started |
14th Oct, 2010 at 05:37:24pm
a 286 cam is too lairy for a turbo engine. a 266 style came is much better. On 11th Feb, 2015 robert said:
14th Oct, 2010 at 05:40:58pm
would the sw10 be ok for a supercharger or again do you think its too lairy? The turbo build has finally started |
14th Oct, 2010 at 05:43:14pm
you can probably get away with the SW10 on a supercharger setup,
14th Oct, 2010 at 05:45:53pm
sorry abit confused. charger set up? as in supercharger or turbo charger? The turbo build has finally started |
14th Oct, 2010 at 06:32:03pm
Joe means supercharger.
14th Oct, 2010 at 06:55:17pm
just tried to have a look at the gt1752 but cant find anything n it. have searched on here but all i find are peoples links to ebay. whats the difference between that and the T2/3? also how hard is it to put a turbo on? The turbo build has finally started |
14th Oct, 2010 at 07:03:04pm
Search for "gt17" by robert.
14th Oct, 2010 at 07:14:21pm
iv had a look at that site theres a lot of good info on there, rly helpful The turbo build has finally started |
14th Oct, 2010 at 07:21:48pm
wow just tried reading through that thread but its way to technical for me. could you tell me is there a lot of fabrication involved with going turbo? The turbo build has finally started |
14th Oct, 2010 at 07:37:20pm
Forget 37mm inlet valves. Definitely not clever for a turboed engine. On 13th Jul, 2012 Ben H said:
14th Oct, 2010 at 07:39:09pm
If its your first turbo build there is nothing wrong with using the standard metro Carb, turbo, exhaust/inlet manifolds etc.
14th Oct, 2010 at 08:06:59pm
would it be easier to go for a supercharger do you think? i would like to build a decent turbo tho. how come the inlet size isnt good?
1391 Posts Member #: 1686 Post Whore Oxford |
15th Oct, 2010 at 07:22:20pm
I may be totally wrong, but given you've got a bigger valve in there. there is less area between the two valves so more prone to cracking. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
15th Oct, 2010 at 11:24:09pm
exactly that. ^ turbo engines will be developing alot more heat in certain places and hence between the valves being a buit more prone to cracking. ive enlarged my exhaust valves a bit and have sodium filled valves, the inlets arnt a massive amount larger than standard tho. Edited by Rick.SPI on 15th Oct, 2010. On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
16th Oct, 2010 at 04:54:49pm
ok so if the valves are too big and are prone to cracking with a turbo would i find the same problem with a supercharger? The turbo build has finally started |
